How to get 10.9.5 to see Digi 003
Hi There,
I have a new Mac Pro running 10.9.5 and the system was migrated from my previous Macbook Pro. Initially the 003 host light would come on and would work (I could monitor audio) but I couldn't hear any inputs. When I opened the "Avid 003 Family" System control panel it looked broken (see image link below). So I uninstalled the current drivers, downloaded and installed the latest drivers. But now the host light won't come on at all? I've also tried to view the system control panel in a new admin account but it still looks the same. Has anyone else seen this or know how to fix it? Any help would be much appreciated. Cheers Ben https://www.dropbox.com/s/c2wyw89pm0...0_9_5.png?dl=0 |
Re: How to get 10.9.5 to see Digi 003
there is no driver for the 003 that will work with Yosemite.
You will have to go down in OS to Snow Leopard. Even Mavericks isnt supported. Chris
http://www.youtube.com/user/RegenerationMix http://soundcloud.com/regenerationmix http://twitter.com/regenerationmix MacBook Pro, 2.4GHZ, 16GB, Intel Core i7, Mac OS 10.9.1 128 SSD internal HD, 750 GB Internal HD, Pro Tools 10.3.8, Digidesign 003r, Waves 8.0, Final Cut Pro 7 |
Thanks for the reply - things have started working in Mavericks with no issues since the post, Will see how I go.
I just bought a new MacBook pro with 10.9.5. I am having the same issue you stated. What ultimately solved the issue?
I think I manually uninstalled everything (drivers and PT) then reinstalled.
I find the organisation of the Avid site painful so can't find the guide I used but as long as you find the latest drivers and PT for your OS, it should work. I've also had no issues using it with other software like Reason - it all seems pretty stable (for me at least). I'm also using it with a Thunderbolt to Firewire adapter because I have a new Mac Pro – not sure if that makes things better or worse! Hope that helps. Cheers Ben |
Digi hardware - bizarre behavior - Digi you will lose this market share | andre67 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 27 | 02-26-2010 07:45 PM |
Digi TS: Problem w/current Digi Core Audio Manager | Armando | Pro Tools TDM Systems (Mac) | 4 | 10-11-2006 10:08 AM |
Digi 002 vs Digi 002R W\Mackie Control Universal | Lance Driskell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 02-28-2006 12:41 PM |
Digi - Reinstalled OS, PT LE, can't reauthorize Digi 002 pack plugins | OneMadSon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-04-2003 04:20 PM |
Wha is the name of the digi cable to hook up Apogee digi 8+ card called??? | leon777 | Pro Tools TDM Systems (Mac) | 4 | 04-15-2002 02:44 PM |
