Go Back   Avid Pro Audio Community > General Discussion & Off Topic > Training
Old 01-05-2021, 02:08 PM
2crows 2crows is offline
Default PT cert
hello , i have started taking the PT cert course, my question is , how do you retain the information about Hz and bit rate ect . with nothing to relate it to, i am trying to memorize it but it doesn't stick,
thankx
Old 01-05-2021, 02:48 PM
Ben Jenssen's Avatar
Default Re: PT cert
Shooting from the hip, here; in Setup menu you'll find "Session", which shows the session info.
Life-long audio enthusiast and small studio owner. Retired.
Mac Mini M1, 16GB RAM. 512GBinternal(3000MB/s),2TB(1300MB/s),2TB(350MB/s)
MacOS 11.6.8. PT 2020.12.1 (Reinstatement on hold for M3 macs and AS native PT)
Topping D50 DAC, Dynaudio BM6p, Artist Mix, SSL UC1, EuControl on iPad.
Old 01-07-2021, 11:07 AM
EdgarRothermich's Avatar
EdgarRothermich EdgarRothermich is offline
Default Re: PT cert
thankx
I'm not sure I understand your question, what information are you referring to?
Are you sure you mean "Bit Rate" and not "Bit Depth"
BTW: THe Session Dialog in Pro Tools has no information about Bit Rate because this is a unit used for compressed audio files like mp3 or AAC.
Edgar Rothermich
Author of "Pro Tools 2020 - How it Works"
from the Graphically Enhanced Manuals (GEM) series
http://DingDingMusic.com/
YouTube Channel Music Tech Explained https://YouTube.com/c/MusicTechExplained/
Old 01-11-2021, 01:51 PM
Default Re: PT cert
hay , thanks , i guess i dont know enough about it yet to even ask a question,
Old 01-11-2021, 02:36 PM
Top Jimmy's Avatar
Default PT cert
You simply need to understand the process of sampling and quantizing.
The compact disk standard sampling rate is 44.1 kHz. To state it simply, that means the audio is sampled 44,100 times per second.
The compact disk quantization standard is 16-bit. That is, 16 binary bits are used to measure the amplitude and polarity of the audio waveform per sample.
The only other thing you should know is the Nyquist theorem which states that a sampling rate can recover any frequency up to half of said rate. So, on paper this means a compact disk can play back frequencies up to 22.05 kHz.
If you can understand this, you can grasp that there can be different sampling rates, and different quantization levels (bit depths).
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Mojave 10.14.6.
Pro Tools Ultimate 2021.12, HD Native, Focusrite Red 8Pre (Mac)
Pro Tools 2020.12, Mbox3 (Win)
Old 01-12-2021, 11:50 AM
Default Re: PT cert
And one more important thing you have to know in that context is that Bit Depth is often confused with Bit Rate:
Another term for Bit Depth is Resolution or Bit Resolution with the units of bit (16bit, 24bit).
However, Bit Rate is a different thing with the unit of "bits per second" which is used to describe compressed audio file (mp3, AAC), when you choose to encode your audio file in one of those formats, you will find a selector that gives you the option to choose the Bit Rate. Of course, higher is better.
Here is a screenshot of Pro Tools when you bounce to mp3 and ou can choose the Constant Bit Rate from the selector. The unit here is kbit/s = kilobits per second".
Edgar Rothermich
PT Cert. Jerry.VC Training 3 11-11-2015 11:34 PM
The Free Opportunity is Now, The Career Benefit is Forever for Pro Tools 9 Cert dvasquez General 0 01-11-2011 04:41 PM
Pt Expert Level Cert scottleader Pro Tools TDM Systems (Mac) 7 10-23-2008 10:24 AM
PT Training-not taking cert.classes-teaching them AVGuru1 General Discussion 3 11-30-2004 05:04 PM
