missing output option under Control Panel
I used to have the option under the Sound menu in the Control Panel to use my Digidesign hardware (888/24 I/O) as an output for the Sound Manager instead of that nasty, little built-in Mac speaker when not using ProTools. After doing a computer upgrade and a re-install of everything, that option doesn't show up now.
What can do to get that back? -bross |
Re: missing output option under Control Panel
Reinstall it from your ProTools CD. Just click install then check the box for Digidesign Control Panel. Install, restart and you should see it come back.
You can also download from: http://www.digidesign.com/download/sndrvr.html
You should have: OS 9 Mac OS installed Digidesign® Control Panel in System Folder/Control Panels You should NOT have either of these files in your System Folder/Extensions folder when using the Digidesign Control Panel: Digidesign Output Drivers Digidesign Sound Drivers If you are still experiencing problems after installation and restart, delete "Sound Preferences" from your System Folder/Preferences folder. Restart, choose Digidesign in your Sound Control Panel output, then follow instructions for using the Digidesign Control Panel: http://www.digidesign.com/support/re...EV_ReadMe.html
Administrator Avid Pro Audio Community |
Thanks!
-bross |
002 Rack not showing as option in windows control panel (sound settings) | TheRealJayP | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 12-08-2009 04:14 PM |
missing Lightbridge control Panel | wildplum | Pro Tools M-Powered (Win) | 1 | 01-23-2008 08:31 AM |
More than one Digidesign output listed in Sound Control Panel | EricWillhelm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-01-2002 02:23 PM |
001 interface icon doesn't appear in mac sound output control panel. | Mark Newall | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-21-2002 10:00 PM |
Control Panel> Sound> output> Builtin or Digidesign. | Karamella | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-13-2002 09:24 PM |
