exciter plugin for protools le ?
hello everybody,
i'm looking for an exciter plugin, that i can use in protools 7 le. just can't find it, anybody knows some ? i just come back home after some time with logic 7 to the protools family, but there's just this little plugin in logic that i really like to use ! greetings, johan. |
Re: exciter plugin for protools le ?
i not familiar with any rtas exciters for PTLE--BBE makes a VST one, and you can use a RTAS-VST wrap like FXPansion VST to RTAS Plug In Wrapper
things like Sony's Oxford Transient Modulator or Inflator can do some things "like" exciters, but not really the same thing--personnaly, I avoid exciters like Aphex & BBE--i think they fool your ears |
that's a good point chrisk23, to use a vst wrapper. i haven't thought of that route !
i shall check it out. btw it's just what i was planning to do : fool your ears greetings, johan. |
izotope ozone
waves tap delay , there is a pre made setup of this plug that is an emulator of an vocal exciter and it sounds very good
Pro Tools 12HD HDX 1 Avid HD 8x8x8 Avid Omni HD MacPro 2.4 Xeon 8 core 24Giga UAD-2 And most of the UAD plugins All AAX DSP and Native Plugins (all most) Tons of Hardware...:) |
what do you mean "fool your ears"?
either you hear it, and like it...........or you don't. or Does the exciter intercept the signal between your ears and brain and insert some tricky codes before you decide? Try the demo of the sony inflator.....its very good! Also another way to get definition on a vocal without a exciter is try this plug in order: 1.Desser 2 eq with highs added (and maybe a 2k-4k bump too), a HPF maybe around 180hz +/- 3.compressor w/fast attack, med release @ 2:1-4:1 4.Desser #2 5. Waves Ren Vox compressor you have to have all the plugins open to watch the push/pull of the signal flow to get the balance right, also to adjust the crossover point on the desser's (that is dependent on the singer's sound and tone)
www.LiveFromDarylsHouse.com |
thanks, everybody.
maybe it should be : fool your eyes ?? but serious, i don't want to use it on vocals but on percussion. i do a lot of latin mixing and i did develop a sort of working method with the use of exciters in logic. it's just not the same with eq. i haven't find a good plugin 'till now, so i'll keep on searching.. greetings and thanks, johan |
Waves Aphex Vintage Aural Exciter® plugin | bacchus40 | Pro Tools 10 | 4 | 08-01-2012 07:02 PM |
Aural Exciter | audiofp | Pro Tools TDM Systems (Mac) | 6 | 10-30-2010 11:35 AM |
Aural Exciter plugin | mushmouth | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-21-2005 03:07 PM |
aural exciter | DHS | Tips & Tricks | 5 | 10-20-2004 04:40 PM |
Aural Exciter Plugin For PT LE | SuperT | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 06-09-2004 07:20 AM |
