Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 01-14-2023, 08:34 PM
langa101 langa101 is offline
Default Can I use Carbon ADAT OUT with 8 Preamps Simultaneously
Hi All,
I'm aware that the DB25 I/O cannot be used simultaneously with the 8 preamp inputs. My question is can I send 16 outputs via ADAT and have it come in and record via the 8 preamps ?
I will send signals out via ADAT to outboard gear for processing via passive summing and bring the signal back into protools that is why I need 35 DB gain via the preamp inputs but need them both at the same time.
Thanks for your assistance
Langa
Old 01-15-2023, 03:45 AM
dominicperry dominicperry is online now
Default Re: Can I use Carbon ADAT OUT with 8 Preamps Simultaneously
Your question isn't entirely clear.
Can you go out of 16 ADAT channels and come back into 16 line inputs - no, the Carbon only has 8 line inputs.
Can you go out of 16 ADAT channels an come back into 8 line inputs - yes, assuming you are DA converting those 16 channels external to the Carbon, summing in analog, then bringing only 8 or fewer channels into the Carbon.
Can you go out of 16 ADAT channels and come back into 16 ADAT channels - yes, assuming all your conversion DAC and ADC is going on externally to the Carbon.
Of course, if you use 16 ADAT channels you are limited to 44.1 and 48KHz.
There will be a delay between the output and the input so any summing you record will be later than the output tracks - I'm guessing about 4ms at 48KHz. The actual round-trip delay is about 8ms.
Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.6.6, Pro Tools 2023.12.1, Carbon.
Old 01-22-2023, 01:11 PM
Thanks for your contribution. To rephrase using 8 ADAT outs the following would be true.
Can you go out of 8 ADAT channels and come back into 8 line inputs - yes, the Carbon only has 8 line inputs.
This is correct right ?
Thanks a bunch
Old 01-22-2023, 02:03 PM
Thanks a bunch
Yes, that is correct, you can go out of 8 ADAT channels and bring 8 analog channels in (e.g. from a summing box or outboard) at the same time.
Dominic
Old 01-22-2023, 02:17 PM
Perfect exactly what I needed. I appreciate the prompt assistance.
Can Carbon be run simultaneously with UAD satallite TP Audio Pro Tools | Carbon 10 08-14-2022 12:17 PM
Carbon with 500 rack- bypassing the preamps / connectivity darkwavo Pro Tools | Carbon 19 06-12-2022 08:09 AM
Carbon Preamps for Classical martthie_08 Pro Tools | Carbon 5 12-23-2021 05:17 AM
Carbon Quality Preamps diogomusique Pro Tools | Carbon 12 09-24-2021 05:57 PM
What I need to run my PT 4.1 simultaneously with ADAT? Girts Tips & Tricks 2 11-16-2000 03:45 PM
