Multi-drive SSD bay? What's good?
Thinking ahead about the MacStudio... I have four or five SSD drives that I use for samples w/ my trashcan MacPro. Currently, two drives are housed together in a single unit, and the others are in their own cases. That's a lot of boxes (and cables) where I really just need one, or perhaps two, bays for everything.
I'm not finding a lot of options for something like a 4-bay enclosure. What do you all use? Ideally, it would be Thunderbolt-4 but I could make a TB-3 work. Last edited by Eric Lambert; 04-02-2022 at 05:21 PM. |
Re: Multi-drive SSD bay? What's good?
You talking 2.5" SATA III SSDs? Or M.2 PCIe? I assume the earlier but want to be clear. Hopefully you are after JBOD (yes please) or software RAID not hardware RAID.
And how big are each of these drives? Make/model might even help. Esp. in any scrap/replace advice. And how much $$$$... the older really nice SATA boxes can get expensive, and I'd personally not want to stick with SATA if it was going to cost a lot more than moving to M.2 PCIe drives... but that can also get expensive and there are not great enclosures available there today. Edit: It it was 2.5" SATA I'd look at the OWC chassis, and personally just use them JBOD--which I think si what you ARe asking if you just want to use them as is but in a better chassis.). Disclaimer: I don't' owe these OWC chassis, almost all my storage is M.2/PCIe SSD, and I'm often critical of OWC storage products but these look good from a price/feature viewpoint, and a big feature is *not* having hardware RAID. https://eshop.macsales.com/shop/thun.../thunderbolt-3 ... but does not have mains power/internal power supply, does not have retention for the power barrel connector, but does have retention for the thunderbolt connector. Hopefully the large Noctura fan is nice and quiet but would be good to hear from others. Last edited by Darryl Ramm; 04-02-2022 at 07:11 PM. |
I have not used that particular Thunderbay mini. The previous generation of that and the "Mercury Elite Pro Dock" did not use Noctua fans. More importantly they are not controlled by a thermostat or fan controller so they run full time at high speed. No big deal if you have a machine room but unusable for audio if not. It seems like they switched to Noctua fans after they had so many returns of the noisy enclosures. Maybe the current models are more tolerable.
~Will |
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit |
Since I already own these drives, I'd rather continue to use them. "New" drives could be purchased in a different format, but that's further down the road. As for $$$$, I'd rather keep it $. And there's that potential issue of having 4 drives powered by a single power supply -- if the PS goes out you lose 4 drives. Not good. So I'm fine spreading these across a couple of enclosures. Maybe 3 drives in 1? That OWC is pretty close to ideal I suspect. |
I'd go for the Thunderbay mini then. They have it listed with and without SoftRAID. It's cheaper without and you won't need it.
~Will |
Good multi-band envelope filter? | Josh Voyles | AAX Plug-ins | 16 | 11-10-2015 05:47 AM |
only1compressor on multi-miced guitar tracks:good? | seth666 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-22-2005 05:27 PM |
Multi Disk Drive question | vocalize | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-09-2005 06:52 PM |
looking for a good multi-channel soundcard to use with pro tools free | edd-- | Digidesign Hardware & Software | 4 | 11-20-2002 06:37 AM |
Anyone know of a good multi-band compression plug-in for LE/001? | RobbaDobba | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 02-28-2001 03:06 PM |
