Old 07-19-2001, 08:55 AM
Burton Burton is offline
Default Too long for comfort... problems with long session files
Since I had the whole studio mic'd up (5 X drums) (2 X Guitar) + (1 Bass DI), I thought that I'd record the band's most recent practice. The practice was about 80 minutes long, with 8 separate tracks recording. Everything seem fine and then I bounced to disk for another 80 minutes. The bounce appeared to work correctly, and the audio sounded correct during the bounce. However, when I burned the resulting AIFF file to disk, it was all scrabled. Start and stop times for the various tracks appeared shifted.
After waiting 80 minutes to complete this bounce, I'm obviously reluctant to repeat this process again. Has anyone else had trouble bouncing long sessions to disk? I'm using a G4 466mhz with 512 megs RAM and 40gig IDE Maxtor dedicated audio drive. PT version 5.1.
Old 07-20-2001, 06:51 AM
DigiTechSupt's Avatar
Default Re: Too long for comfort... problems with long session files
-Import the bounced file into a session...what is the quality of the audio? If it is clean, then something happened during the CD burn.
-If the audio is "dirty", bounce a portion of the session to your system drive and see how it sounds.
-What format utility did you use on your audio drive? We recommend Apple Drive Setup for all ATA drives.
Brent
Avid Audio Tech Support
Support FAQ
Importing many session files to make a new long session velwestvoices Pro Tools 10 4 04-30-2012 03:38 PM
can't import long name files? mano111 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 19 07-11-2011 05:39 PM
how to trim long files, please help brill bedroom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-03-2005 11:00 AM
Best way to break up long session into many files? illovich Tips & Tricks 2 01-28-2005 02:53 PM
Long, long Time loading PTLE on G4 DP 1.25!! pockets745 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-30-2004 05:09 PM
