Plugin Presets
Hey, Just wondering if anyone knows how to load multiple plugin presets for multiple plugins, all at once. Thanks. -Bruvey
Two muffins in an oven. One muffin says too the other,Damn it's hot in here. The other muffin says,Holy shyt, a talking muffin! |
Re: Plugin Presets
I think the way it works is: Ya 'import' what you want from the System>DAE>Plug-In Settings Folder for each plug (or you can create from scratch and save)...
Then a session plug-in folder is created (automatically) for each plug (and will pop up from then on as you click on the 'factory default' bar) and the settings you import or create follows each plug and the session. I haven't stumbled across a way to 'load' a bunch of settings at one time. The Virus synth, for example, has been the subject of frequent and unhappy posts regarding having to load sounds one at a time... |
Re: Plugin Presets
Thanks for the info, but my problem is getting many presets for many plugins. By doing it that way I can only choose one preset at a time for one plugin and that would take a real long time. Any ideas? -Bruve
Re: Plugin Presets
I usually have the time to call up the stuff I need... one at a time. But if it gets to the point where I'm calling up the same plug in settings for the same tracks, I would save a template with my favorite stuff already there. I'm pretty sure that's the easy way to go.
Re: Plugin Presets
That's true. Shouldn't take too long to load-when-you-need presets. Thanks [img]images/icons/smile.gif[/img]
Hypercontrol: Convert plugin build-in presets to pro tools plugin presets | headsup | macOS | 4 | 12-17-2011 01:28 PM |
Plugin Presets? | zimbu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 04-25-2008 02:45 AM |
plugin presets? | fasttraxx | Tips & Tricks | 14 | 07-01-2007 11:09 PM |
why cant I see the plugin presets | Enis Presheva Jr. | Pro Tools TDM Systems (Mac) | 2 | 10-01-2001 04:55 AM |
Plugin presets | Vegadark | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-10-2001 07:56 AM |
