Old 07-02-2006, 06:21 PM
meltdown5 meltdown5 is offline
Default compatable?
ok well i ended up returning my other computer becuase of compatability issues... i was wonder if you guys could quick do a double check over the following set up to make sure i didnt miss soemthing.... is it compatable??
-Dell Dimension E510 Series Pentium® D Processor 940 with Dual Core Technology (3.2GHz, 800FSB)
-Operating System Genuine Windows® XP Home Edition
-Memory 3GB Dual Channel DDR2 SDRAM at 533MHz (2x1GB,2x512M)
-Monitor 20 inch UltraSharp™ 2007FPW Widescreen Digital Flat Panel
-Video Card 256MB PCI Express™ x16 (DVI/VGA/TV-out) ATI Radeon X600 SE HyperMemory
-Hard Drive 160GB Serial ATA 3Gb/s Hard Drive (7200RPM) w/ 8MB cache
-Network Card Integrated Intel® PRO 10/100 Ethernet
-CD or DVD Drive Single Drive: 16X CD/DVD burner (DVD+/-RW) w/double layer write capability
-Sound Integrated 7.1 Channel Audio
-Hardware Warranty 2Yr Ltd Warranty, 2Yr At-Home Service, and 2Yr HW Warranty Support
-Optional Ports IEEE 1394 Adapter
Old 07-02-2006, 07:11 PM
Default Re: compatable?
looks fine, cant remember if you said your using mbox or 002. if 002 get a compatible firewire pci card for it (in digi compatibility docs) and another internal hard drive. should use seperate drive for system and tracking. the dell's though have not been known to be the best performers and seem to have chipset incompatibilies.
though i must say, spending this much cash i and many others here will say go with an amd x2 base system or even better a QUADZILLA the amd's have proven to perform much better than the intel's, and the quadzilla is the highest performing computer going at the moment. but regardless an x2 based system can be had or better yet built for pretty cheap.
check digi's proven computers on this site as well to see if they say anything about this.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I9 14900k
Win 10
Old 07-02-2006, 07:24 PM
do you guys know where i can get a computer for aroudn this price range that would out perform this dell? im looked to spend right around $1000 for a good recording computer... Im using a 002 rack and pt 7.1
Old 07-02-2006, 07:30 PM
i dont quite understand dual processors... if a its says intel duo core processors at 2.8, does that mean 2 processors each with the power od 2.8 ghz, OR does that mean 2 processors eacj 1.4 that team up to make 2.8? what would be better for pro-tools?
Old 07-02-2006, 08:00 PM
check out the 1st page of "best desktops" thread. it has an x2 machine you can build for 600.00. ( does not have xp listed though, another 100) if you dont want to build it, buy the parts and have a local shop do it. this is a rockin machine allen has left up there. the best way to go.
pro-tools-pc.com
Intel I9 14900k
Win 10
compatable? meltdown5 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-02-2006 06:21 PM
Can someone tell me if PT would be compatable? TamTam 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-18-2006 07:59 AM
Compatable or not? Darkwire 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-09-2004 09:56 PM
Mac OSX.2 compatable with 002r?? farside 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-15-2004 09:58 PM
HELP! Am I compatable? redandwhitefobe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-04-2001 12:31 AM
