Re: CPU usage jumps to 100% when saving if edit window minimized
Hi Guys,
I wrote some posts in the mentioned threads because I had that issue. Hi cpu usage related to the window size or more in general to the gui. Before the 8.0.1 was out I got a new laptop on which PT never showed this issue. Anyway, I tried the update on the old one and I could not experiment the issue anymore. So, in my case, the 8.0.1 update solved the issue. If it can be useful the graphic card on the old laptop is an ATI while the one I'm using on the laptop that did not have the issue also in 8.0cs3 is an Intel. I hope you can solve your problem Ciao Fabrizio |
For anyone with an Nvidia graphics card - which driver version do you have installed? Have you tried the standard Windows driver to see if the behavior is any different? (More info on this in the General Troubleshooting thread...)
One thing I have noticed is that the "Windows Optimization" guide from Digidesign suggests that you turn "Hardware Acceleration" to NONE/OFF on your video card. That's a big NO-NO here, my machine runs like a cow patty baking in the the sunshine at that point. Hardware acceleration on a video card should take almost all the graphics chores off the CPU and let the video card handle them. That's what you want it to do. Turn it back on if it's off and see what happens then.
I may be wrong, but it's only happened just once before and it appears I was mistaken about that.
Gigabyte z390 Designare I9 990K 4.7 GHz 64 Gb of DDR4 3200 Gigabyte RX580 8 Gb Win 10 Pro 15" Mid-2015 MBP 2.2 GHz i7 16 Gb RAM 512 Gb Flash Drive - OS X 10.14.6 |
#16
Hi, thanks for your response. I tried both the windows standard driver and installing the latest nvidia drivers from their site. no change in behavior.
#17
I also tried both the windows standard driver and installing the latest nvidia drivers from their site. No change in behavior, If anything, the windows driver was worse since I dont think it has any acceleration.
#18
yeah using the windows driver wouldn't have been a usable option but it would have revealed if the video driver was the culprit.
it just seems like some weird interface bug to me more than anything related to hardware, but who knows. |
#19
Well - I went ahead and ordered an ATI card for cheap, just to give it a try. Should be here maybe Wed - will let you know what I find but I dont have high hopes....
#20
Well I replaced my Nvidia 8400GS with an ATI EAH4350. Not a bit of difference.
HDN jumps to high CPU usage | propower | Pro Tools HDX & HD Native Systems (Mac) | 1 | 09-30-2013 10:00 PM |
PT 9.0.1 Edit window view jumps forward | collinsylex | macOS | 2 | 02-10-2011 12:58 PM |
pod farm platinum iLok no sound unless plugin window minimized | Jenk2k | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 04-16-2010 05:27 AM |
Edit window and cpu usage | Trazan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 17 | 03-27-2009 11:05 AM |
CPU usage jumps up while doing nothing!! | Andrew B | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 10-18-2003 11:14 AM |
