Moog Modular V 2 and ProTools LE 7.1.3
Am I missing something. I ran the MOOG Mod V update for Tiger and ran the the PT 7 update. Now I have the moog PT 7 moog plugin, Aturia plug and another Moog V doc file in my plugins folder. The problem is when is that now i have 2 choices when i create a stereo instrument track in PROTOOLS . One is Moog Mod V and the other is Moog Mod V2. When i select V2 i am only given channel 1 as a possible midi track output. If I change the plugin instance to "Moog Mod V" iam then given all 16 channels for my midi output. Problem is this instance of the plugin crashes ..immediately on playback....What gives... The V2 instance of the moog works great but lilke i said only on available midi out (ch 1) I have trashed the prefs repaired the permissions, reinstalled the moog etc..... Any help is appreciated, G5 Dual 2.5 2 GB Ram MBOX Pro. ProTools LE 7.1.3 10.4.8 |
Re: Moog Modular V 2 and ProTools LE 7.1.3
When you updated the Moog Modular V2 did you delete the Moog Modular V2 .dpm and .dpm rsr files and drag the new ones into the Plug-In folder?
filosofem
Aaron Mulqueen - 001 HD Native |
Well, you've got me beat! I can't even get the PT7 version to load!! Arturia tech support has told me the Arturia Engine is not needed, so to remove it from the plugins folder. The only Moog plugin should be the 'V2' version. I tried doing a complete re-install, and then doing the updates, to no avail. I've had no problems with the CS80 however. - Greg |
I deleted the dpm. file///where are dpm rsr files located.
I now was able to get the arturia plugin and that other moog v doc out of the plugins folder and have it a least load. For a while when those two were removed protools would give an error that the moog vould not load I am stilling having the 1 midi ch.. problem |
Are you guys running PPC or Intel-based Mac's? Have Arturia released support for Intel-based Mac's?
p.s. I'm running AMD Quad Windows Pro LE 7.1 cs10 filosofem
CS-80, minimoog V, Analog Factory and Brass are currently supported on Intel based Macs. The others are in progress.
Thanks Jeff.
filosofem
Arturia Moog Modular in ProTools LE | wellies | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-26-2007 03:27 AM |
Moog Modular and ProTools | sequence025 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-03-2004 12:12 AM |
ProTools and Moog Modular V. Anybody? | McAlister Skirting | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-25-2004 06:11 AM |
Moog Modular V | Cliffy_Boy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-19-2003 08:13 PM |
Moog Modular | clausiii | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-16-2003 03:07 PM |
