Importing Reason Stereo Files Into Pro Tools
Sup guys
Here is the deal, I've mixed down a song which is panned the way i want it with reason. I've exported it as a .wav and everything sounds great listening to my file with windows media player. Then I import it into pro tools and all of my pans are not even panned right, everything is in the center.....Any ideas on what the problem is? |
Re: Importing Reason Stereo Files Into Pro Tools
If you click on the parent file in the regions list does it list under it 2 file with that name, one with a R, one with a L. If not it may have been converted into a mono wav on importing.
Stupid question: You are using a stereo track to listen to it in PT, aren't you?
"Sometimes having limits keeps you sane"- Albee1952 |
Yea im using a stereo track....
I've been trying to get the regions list up i cant find it....But im sure its a stereo file, when i import it, it says "2 channels".... hmm |
ok i found the regions list....so i tried to insert each .R and .L seperately each in their own mono tracks.....didnt work.....
What didn't work? The waveform showing in the Audio tracks? When you exported the mixdown what file format did you use, .wav or .aiff?
filosofem
Aaron Mulqueen - 001 HD Native |
it is in wav. - - -- -in pro tools it is not panning right, but when i export the song "bounce to disk" from pro tools it is all panned right.....so. i guess all is good now, but i'd like to hear it while im working on it when its in pro tools. if there is no solution, i can deal . . .just kind of ghetto. heh
This may seem dumb... but, did you check to make your you didn't have Mono output selected on the front of your rack or control surface? Pressing that will pan everything coming out of ProTools to hard center for phase analyzing.
Also, if you drop them onto Mono tracks, you have to pan them hard left and hard right manually. |
need info on importing stereo files in 7.3 | PRATHAP | Post - Surround - Video | 2 | 05-07-2007 09:36 PM |
strange problem importing stereo files | technician | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-16-2005 04:50 AM |
ProTools importing stereo files as mono | Dave Steinwedel | Pro Tools TDM Systems (Mac) | 3 | 10-27-2005 01:01 AM |
Importing Thousands Of Files To One Stereo Track | Tweakhead | Pro Tools TDM Systems (Mac) | 1 | 03-27-2002 05:27 PM |
feature request: Importing split stereo files... | uno1234 | Pro Tools TDM Systems (Mac) | 2 | 06-02-2000 08:47 AM |
