Control room wall construction
http://www.clarityrecords.com/layout.html
here's my studio space in a rough computer sketch. I need to build a wall where the dotted line is, and it has to isolate sound pretty well without spending a lot of money any like, parts list, price estimate, or material ideas much appreciated
www.clarityrecords.com |
Re: Control room wall construction
Have you checked out www.auralex.com yet? There's a PDF pamphlet titled "Acoustics 101" that's pretty good at least to give you a starting point.
[ August 28, 2001: Message edited by: maxcap ]
Everyone in this room is wearing a suit, and don't kid yourselves Zappa |
i know there has been several threads on this exact topic in the past. i might be able to dig up the info i acquired from them. a search oughta come up with the info. if you use auralex materials, i think you're looking at around $1-2k. but there are cheaper solutions at your local home depot... it's really not as much of an exact science as some make it out to be. i think rick at superdigital(503.228.2222) is constructing his own dub studio in the store-front building.
happy building(lotsa fun to be had)! you might try trading studio time with help, if possible. [ August 28, 2001: Message edited by: Felix ] |
thanks felix, that's a really good idea trading studio time.
Back in the big Apple we used to put hummasite(sp) under the stud (plate) prior to building the wall. Then a layer prior to the sheetrock (4 firecode) This let the B-52s rehearse without the neighbors 'doing something dreadful' to that singer. Following the same basic concept- but leave off the sheet rock at the control room side. You may need this for firecode however (usually under the console)
Lay the wall stud(plate) on top of hummasite, and secure it in place. Do the same with the ceiling stud (plate actually) and two outside uprights (studs). You may also use adhesive to doubly seal these materials. Frame your wall and window. Wire, insulate and sheet with hummasite, if ok by firecode. And/or cover with 3/4 inch sheet rock. Caulk everything really good. Fir'n strips may be placed on the outside of control room hummasite wall and another layer of hummasite placed on top of that. 3/4 sheet rock afterwards, to paint and as firestop. Close the window frame off with hummasite also. Then sheet rock with 3/4. Install window with rubber boots supplied by window company. You need some kind of track on the bottom of window to bear it's weight across the sheet rock. Silicon everywhere! Apply prefinished mouldings and caulk again. Paint. Voila. C'est fini.
"The original nipper" Throw me a bone (Telefunken DI is ok too) |
Blake ,
this is not quite what you asked for but it is interesting to see how someone else went about things and there is a little info about walls but mainly acoustics and bass traps. http://www.ethanwiner.com/basstrap.html Kev |
Euphonix MC Control V2 - Control room knob PT9HD-HELP | hugoleitao | Artist Series | 3 | 06-09-2012 06:03 PM |
400 Sq Ft Control Room Available in NYC | relaxo | Tips & Tricks | 0 | 03-30-2003 08:49 AM |
Local Control Off is making me hit a brick wall... | cydonia | MIDI | 2 | 08-04-2002 01:01 AM |
How much effect does a Mirror wall in a vocal room? | eddybertrand | Pro Tools TDM Systems (Mac) | 5 | 03-17-2002 07:30 PM |
How Do You Configure Control Room Vol. Control | MeltMediaMusic | Pro Tools TDM Systems (Mac) | 1 | 05-09-2000 10:07 PM |
