Old 10-24-2009, 02:11 PM
soundeziner soundeziner is offline
Default OMF import offset and DUC search
Having problems with OMF imports in PTHD 8.0.1 Result is offset by an hour past where it should be. Mac Pro with Two 2.26GHz Quad-Core Intel Xeon "Nehalem" processors. OSX 10.5.6 OMF coming from FCP.
also
Wanted to look into it on the DUC but a search of "OMF" comes up with "Sorry - no matches. Please try some different terms" I'm pretty certain we've typed 'OMF' here a few times...
Old 10-25-2009, 06:09 AM
Postman Postman is offline
Default Re: OMF import offset and DUC search
What frame rate? Frame rates above 30 are known to do this although I don't recall the offset being exactly 1 hour.
Old 10-25-2009, 07:25 PM
reichman's Avatar
reichman reichman is offline
Certain workflows and/or versions of FCP don't produce an OMF that will land in the right absolute time code on import. I worked on an HD show (23.976) in which the only way I could sync the OMF was with the 2-pop at the head. Everything else about these OMFs were fine, though.
OMFs that I get from Avids always land in the right spot.
I seem to remember discussing this drawback of FCP years ago here on the DUC. Keep searching...
Old 10-26-2009, 01:35 AM
mr.armadillo mr.armadillo is offline
The DUC won't allow 3 letter search terms - a mininum of 4 letters is required.
Try a "site" google search: site:http://duc.digidesign.com "omf"
Old 10-26-2009, 02:52 AM
TAFF TAFF is offline
Hi all,
I'm getting this problem as well. From an Avid Media Composer 25fps sequence.
Paul McFadden
Supervising Sound Editor
Doctor Who
www.bangpostproduction.com
Old 10-26-2009, 08:26 AM
tonepad tonepad is offline
Ask your picture editor what his start mark is. Go to "session" settings in PT and set your stat time to that, then "maintain timecode". Do this with picture and guide track as well. Your 2 pop should fall right into place if you have one to verify all of this, but even without a 2p just knowing start time should do the trick. As a matter of specification we always ask for a 00:58:30:00 start time for everything from OMF to PT templates to ADR etc.
Wilson Dyer mpse
Sound Supervisor NCIS Los Angeles
My day job:
Wilson Dyer MPSE
Sound Supervisor: NCIS Los Angeles, CBS Television
Old 10-26-2009, 01:45 PM
FCP session and mine are both 29.97 Drop
Wilson - yeah that's how things normally should work.
Dunno why but all OMF imports are coming in 1 hour late. The other freaky thing is that no matter what I set the offset to it does not change where the files land. Same exact placement every time.
I am working on really short pieces right now. Sync by hand is very easy but I'd like to have the OMF import function work like it is supposed to (and always has for me).
Mr. Armadillo - Thanks! Unfortunate limitation for troubleshooting OMF issues but now I know.
Todd A. Judge, MPSE
Old 10-28-2009, 12:30 PM
ABrooks ABrooks is offline
Can you not go in and change the session start time to 1:00:00;00? Then? I've seen that happen where our editors will send over an OMF with their session start time at 1 hour instead of at 0, and all I have to do is simply go in and set the session start time to 1:00:00;00 and it pops right into place.
HTML code is On
AAF import from AVID has 1 sample offset Tim R. Pro Tools 10 1 08-10-2012 01:15 PM
Import Session Data offset (bug?) CCash Post - Surround - Video 5 01-25-2012 10:59 AM
9.0.6 still didn't completely fix the Import Audio search field bug mattyharm Pro Tools 9 3 01-22-2012 10:14 PM
Import Audio search window results will not import BA Studios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-25-2008 09:00 AM
Search feature in import audio window Studio Studio Pro Tools TDM Systems (Mac) 9 06-19-2007 03:51 AM
