#301
Re: Automation AppleScripts for Pro Tools (Mac)
Maybe post your script to see if there are any issues within. |
#302
Hello all,
I have attached the code of my script which has worked for years. PHP Code:
Thanks in advance |
#303
Hi, this works fine here with Pro Tools 2021.7. |
#304
Oliver, if you create a Pro Tools Service with this script and then execute the service using a Mac OS shortcut key, do you get the triple click of the Render?
This was my issue I posted a couple of weeks ago. Seems like Audio Editor is having a similar issue. This might be an OS issue rather than a Pro Tools issue since the script runs fine when test in Automator or Script Editor. I’m on 11.4 w Mac Mini M1 |
#305
It seems like you have to carefully choose the shortcut. Example: Using the shortcut ⌃⌥⌘+Y does not work, it triggers the script 3 times. ⌃+Y works fine though. Play with the shortcuts or stick with Keyboard Maestro or FastScripts. 😉 |
#306
Hey Oliver,
thanks for testing. Unfortunately I can't reproduce this on my system. For years the default setting for me was ⌘+f16. No matter which combination I used each time the script seems to be executed 3 times. Neither ⌃⌘+f16 nor ⌃+c changes anything. |
#307
Hey Oliver,
thanks for testing. Unfortunately, I can't reproduce this on my system. For years the default setting for me was ⌘+f16. No matter which combination I used every time the script seems to be executed 3 times. |
#308
Funny. I wasn’t using any modifiers with my shortcut key. It was simply F17 |
#309
Hey all
thanks for testing. My RX shortcut in the last years was ⌘+F16. Unfortunately it doesn't seem to matter which assignment I give the script is always executed 3 times. Seems like I really need to make friends with an alternative to Automator. |
#310
This is such an annoying bug in the Mac OS. I'm only witnessing it in Catalina and Big Sur.
If anyone has an OS based workaround please post it in this thread. Thanks |
Pro Tools 12 Trim Automation | [email protected] | Pro Tools 12 | 2 | 08-16-2015 04:25 AM |
Pro Tools 11.2.1 Automation Bug?! | Gneal550 | Pro Tools 11 | 1 | 11-22-2014 01:15 PM |
GRM tools automation bug? | D'Animation | Pro Tools TDM Systems (Mac) | 6 | 10-08-2014 08:21 AM |
scripting Pro Tools; automation | Bermaster | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 10-01-2004 12:38 PM |
AppleScripts and other Macros for PT | Bergeron | Tips & Tricks | 1 | 11-15-1999 06:55 PM |
