Old 08-14-2002, 06:53 PM
radioface radioface is offline
Default vocal thickness
does any one have any suggestions on thinning a vocal so it still has body but is not over present?
Old 08-15-2002, 02:17 AM
vonbleak101 vonbleak101 is offline
Default Re: vocal thickness
Boost the low mids 250 - 500 by a little (3-6db)and about 12k by the same. Also try compressing the vocals so you have about 6db of reduction but only boost the output by about 3db. If worst comes to worst use Maxim if you have it. [img]images/icons/grin.gif[/img]
Audio Engineer/Musician/Producer
Old 08-15-2002, 11:32 AM
thanks for the tip!
I ended up using a C4 and toned down the pop vocal preset. Worked great! Thanks
Old 08-17-2002, 05:16 PM
Rational Punk Rational Punk is offline
C4 (and C1 using the filter section) have made life much easier for me in regard to these kinds of issues, but I still can't usually get away with finding a single "magic setting" and letting the vocal glide through it for the entire song. There always seem to be a few syllables or phrases with a more pronounced proximity effect that need to be trimmed a little more below 400Hz or so. But using C4 has definitely cut down on the number of those kinds of manual EQ adjustments. Another area where C4 really shines is creating a consistent presence in vocals and lead instruments while shaving off piercing, ear-fatiguing presence peaks. One heck of a tool.
Project Vector.com
Progressive techno rock
The new CD, Reality Show, is now available.
Vocal Comp or Vocal Limiter? tommydigiowen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-03-2011 06:34 PM
Adjust Grid Thickness? CHAD S SMITH Pro Tools TDM Systems (Mac) 3 11-16-2009 08:23 AM
Vocal Mic and Vocal/Instrument Preamp vsideproductions Tips & Tricks 5 09-22-2006 04:17 PM
DBX Pro Vocal digital vocal strip xprod77 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-06-2003 05:53 PM
One Vocal mic to buy? Blake Henderson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 32 02-05-2002 12:48 AM
