I am having trouble getting my Roland Juno-G to communicate correctly with Pro Tools. I am using a Mac OSX 10.9.4 and I'm interfaced with a Roland UM-ONE, USB out the back of computer to MIDI connectors on the back of synth. I have been in contact with Roland and they have been trying to help me. I don't know if this is overload, but I think the best way to include all of the details is to copy my last 2 communications into this email. I'm hoping someone will read the following and chime in with some help.
Stuck in Derby, New York Thanks, mark Aug 29th 3:30am: My email to Roland I have set this up exactly as you have outlined here. If the Remote switch is set to off I get no sound on playback. If I turn it back on I get all tracks sounding with the same timbre the live keyboard is set at, even though I have set the output of each track for a different channel. If you have any other ideas they are welcome. I am going to try to bounce this problem over to the Protools support people and see if there is something I can/should be doing within the program. Once again, I am new to Protools. Thanks for sticking with me. Aug 29th 2:30pm: Roland's reply Hi Mark, The Remote Keyboard switch does channelize any incoming MIDI so that it only plays what the keyboard of the Juno-G is playing (it is mostly intended for use with a remote keyboard in a live performance situation), so this is why you are getting all of your different tracks / MIDI channels playing the same sound. The Remote Keyboard switch definitely needs to be OFF if you want to be able to access different sound on different MIDI channels in the Juno-G. If you are getting no sound when this is set to off, we would suspect the tracks / channels in Pro Tools are not matching up with what is set up in the Juno-G, but please let us know if the Pro Tools folks have any other ideas on this. Best Regards, Product Support Roland Corp. U.S. |
Have you setup the instrument under the midi studio setup, and then used the midi input selector on the instrument track (the drop down menu that says all) to use the Juno?
![]() Quote:
I'm confused about something - are you using USB or 5 pin MIDI to communicate between PT and the Juno? And do you have the right one selected on the Juno? Not all keyboards work on both USB and 5 pin MIDI at the same time. Is the Juno multi-timbral on 5 pin MIDI? It might not be and your recourse would be USB MIDI. Is there some kind of mode you have to be in on the Juno to do multi-timbral? You need multi-timbral if you want different sounds on different incoming MIDI channels. I gather you're using the Juno as a sound module and bringing the audio back into PT through the UM-One. |
Manny,
I am connecting the Mac to the synth with a UM-ONE interface. It is a USB connector out the back of the computer and then a 5-pin to the IN and then another to the OUT on back of the synth. This was the interface I found that worked. the machines are communicating. The system setup on the JUNO-G is: USB MODE - MIDI..... The other option is STORAGE. Roland is telling me that the Sequence Template is the set up for Multi-Timbral playback. My audio is running out from the synth to the amp for my stereo. p.s. If I hook up my old JV-80 I can get multi-timbral playback and my click track is a percussive 'click'. The JV-80 is in poor condition and I'm loathe to go back to it. |
![]() Quote:
Emcha_audio,
Thanks for your reply, it takes me back to the very beginning of this quest. I have never been certain that my MIDI STUDIO is setup correctly. I have 2 UM-ONE icons in the setup box connected to each other. OK, so I just deleted one of the UM-ONE icons and created an icon for the JUNO-G. first thing that happened was the tracks I've already created became grey. I get no sound at all. So I created an instrument track. The midi input selector says 'no input' (not 'all'), and the Midi tracks now say JUNO-G instead of UM-ONE. Mark |
![]() Quote:
Proper setup in OSX audio/MIDI setup is a must. If you're using the traditional 5 pin MIDI you have to make connections from the Juno to the interface. One thing you MUST check is can the Juno do multi-timbral by way of 5 pin MIDI? You keep ignoring that little bit. |
musicman691,
The UM-ONE is only 5 point Midi cables on the end going into the synth. It is USB into the back of the mac. I have used the 5 pin midi cables years ago with my JV-80 and had no problem getting multi-timbral playback. So I assumed that I could continue to use them. I have indicated to Roland that I'm using them and they have not told me different. I'm still not certain of my Audio MIDI setup. I thought that the computer was supposed sense the presence of the synth and give me the representative icon. Instead, I created the icon for the JUNO-G. It wasn't automatically an option through the MIDI window. mark |
![]() Quote:
I am in USB MIDI mode on the synth. I went into the menu and checked the setting. In the settings window I can toggle between USB MIDI or
USB STORAGE. Those are the choices. When I test the setup here's what happens: I click the out port on the UM-ONE icon and I get what sounds like and 'orchestra hit' and the in port on the UM-ONE icon blinks. Are you also saying that I need an interface that is USB to USB? |
Roland Juno 60 Vintage Analog Synth - Juno-60 FREE SHIPPING | nexis | Buy & Sell | 4 | 03-28-2013 02:02 AM |
Roland Juno Di - Midi ( Via USB to computer ) Not working. | j.muttathu | MIDI | 0 | 08-05-2012 05:00 PM |
Roland JUNO Gi and Pro Tools SE. | Laurenz Roth | Pro Tools SE and Essential (Win) | 2 | 04-05-2012 03:17 AM |
mBox2 + Roland Juno-106 | Jasari149 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-19-2008 08:00 AM |
Roland Juno-G with Pro Tools | midiman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-17-2007 05:57 PM |
