Old 04-15-2011, 12:03 PM
georgeearth georgeearth is offline
Location: Echo Park , Los Angeles, CA, USA, Earth , Milky Way
Unhappy I give up! Can't make PT8LE record midi from Yamaha PSR730 using Midisport uno
Should I try a different keyboard? I've done everything else, downloaded most recent drivers, took the Midisport uno back to the store and replaced with another one....below is my original post (which NO ONE had any reply to): I have PT8LE on a Windows XPS2 PC with a Mboxmini which has not midi input, so I just got a M-Audio Midisport Uno USB cable/interface, and it does not seem to be able to get midi from my Yamaha PSR 730 (I did read somewher that the M audio midi/usb cables had issues with that synth)...
The synth DOES show up in the options/midi studio in pro tools, so it does seem like that much of the UNO cable is working...another issue was the install, which told me it was not right version for my Windows, then I found the updated driver on the MAudio site specific to my XPS2 and installed that, but it still says there is some issue with the install and that the device may not work properly (which, no, it does not)...my midi internal to PT8 does seem to work fine, I can draw midi with the pencil, and play it using Xpand2.
And of course all audio works fine, including audio from the PSR730 synth.
I did follow all of the guides for setting the I/O's etc.
I have not tried using another midi controler othyer than the PSR730.
Old 04-15-2011, 01:17 PM
Default Re: I give up! Can't make PT8LE record midi from Yamaha PSR730 using Midisport uno
Try another USB Port, perhaps this will re-run the driver/communication. Is 'Local Off' on the Yamaha keyboard? When you open the Output Selector for a MIDI Track is the M-Audio MIDISport listed?
Aaron Mulqueen - 001 HD Native
Old 04-15-2011, 01:42 PM
Hi Filo, thnx! I did try a different port, and tried with "local off" as well as "on",
and nowhere in pro tools does the midisport show up, though the psr730 does show in in options/midi/midi studio, but in midistudio it only has the name but no ins or outs. Wondering if I should try a different keyboard (which I don't have yet) or if it is an issue with the midisport.
Old 04-15-2011, 01:50 PM
Windows>Device Manager>USB Controllers is the MIDISport Uno USB listed? Which driver version have you installed, 4.3.00?
Old 04-15-2011, 01:56 PM
thnx Aaron/filo! Not at my rig right this sec so not sure about "Windows>Device Manager>USB Controllers is the MIDISport Uno USB listed" question, but yes, the MA CM101 V32 4.3.00.exe driver
Old 04-15-2011, 02:03 PM
Uninstall all drivers relating to the MIDISport Uno USB device and remove the MIDISport Uno USB device from your computer and restart. Reinstall the MIDISport Uno USB driver 4.3.00 and once the driver installation has finished unless told otherwise then plug in the MIDISport Uno USB device. Will the MIDISport Uno USB device show up in the Device Manager USB Controllers list?
Old 04-15-2011, 02:25 PM
Hmmm, I did uninstall several times, did that each time I tried to install the new driver (which I downloaded 2 different times just to be sure) though I never restarted the computer without the driver installed....I never checked the device manager list, is that in PT or on the computer?
Old 04-15-2011, 02:37 PM
Windows XP>Control Panel.
Old 04-15-2011, 06:38 PM
zedhed's Avatar
zedhed zedhed is offline
I would install XP Service pack 3 & then follow Filo's instructions.
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 2024.6 Avid Omni/2 x Fractal AxeFxIII
HD96 I/O
Adam A8H Monitors + A12 Sub
Old 04-16-2011, 08:34 AM
My M-Audio UNO worked great on Windows XP. Won't work at all on Win7
I wish AVID would just give up on HD Native and make this box -- propower General Discussion 9 03-26-2014 01:03 PM
Plug-ins make sound but won't record/write MIDI! scottheiner MIDI 1 09-16-2011 11:46 AM
PT8LE Locking Up Every Time I Hit Play To Record ducmike 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-28-2010 07:01 AM
did I make a mistake buying a midisport? Tito Ricci Arballo MIDI 3 08-28-2007 05:12 PM
This Will Make PT 7.1 CS 4 Give U A Spinning Ball 25ghosts Pro Tools TDM Systems (Mac) 0 02-15-2006 04:59 PM
