Old 11-16-2009, 08:09 AM
CHAD S SMITH CHAD S SMITH is offline
Default Adjust Grid Thickness?
I heard a rumor that in PT8 you can change the thickness/width of the gridlines, I am NOT talking about grid value. I simply want to know how to darken/thicken/widen the grid lines that appear in the edit window (if possible), Thanks!
Old 11-16-2009, 08:15 AM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Default Re: Adjust Grid Thickness?
Try Ctrl/Opt & the plus or minus key...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 11-16-2009, 08:19 AM
That changes the VALUE, I want whatever grid value I am working at (i.e 1/4 note value) on the edit window to be thicker if possible. Thanks for trying to help!
Old 11-16-2009, 08:23 AM
Oh; my bad...I guess a rumor is all that it is...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
When loop is TCE'd to grid then duplicated out, it doesn't match the grid. STSCRUSHER Windows 1 11-23-2012 09:34 AM
Slip to Grid mode no visual grid unless pressing "grid" mgoorevich Pro Tools 9 5 11-13-2010 07:11 AM
Grid BUG - PT fails to snap to grid when zoomed out 25ghosts Pro Tools TDM Systems (Mac) 0 04-18-2009 07:54 AM
Fine adjust fader in edit window caput! command+adjust crizdee Pro Tools TDM Systems (Mac) 2 12-09-2008 03:55 PM
vocal thickness radioface Tips & Tricks 3 08-17-2002 05:16 PM
