Hey all! I'm new to the forum. I'm coming from a Metric Halo ULN-8 and I'm trying to figure out if my Carbon can be set up in a 2.1 monitoring configuration with volume control from the volume dial on the face of the unit.
I want to used Dirac Live Processor with Bass Control to be able to dial in my JBL 708p's and Adam Sub 12, but I'd like to continue using the Carbon as my monitor controller. Is this possible? I've seen how to do it for 5.1 or Atmos, but not a simpler 2.1 configuration. Any advice? |
There is no 2.1 surround configuration on the Carbon - only 2,6,8 or 10 channels. So you would have to fudge it - there is no way I can think of to control a 2.1 with the volume control of Carbon (short of using the 6 channel configuration as 5.1 and then not using 3 of the channels).
I use a Genelec 7070 sub, which is in-line, so only needs two channel output from the Carbon. EDIT: I can see the Adam sub has the same option to run in-line as the Genelec, but I don't understand how the Dirac works - is it a physical device or software - I assume you are trying to control the sub level separately from the rest of the mix? Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Sequoia 15.2, Pro Tools 2024.10.2, Carbon. Last edited by dominicperry; 12-29-2023 at 04:58 AM. |
I think you're correct that there isn't an easy way to do it. Dirac is software based and Dirac Live Bass control helps phase and time align subs with the mains (and surrounds if you're using them). You need an unused output for each sub. The tricky part is controlling the volume of all of them after running the room corrections.
Pro Tools | Carbon & Carbon Pre compatibility with AVID S4 Control Surface | [email protected] | Pro Tools | Carbon | 9 | 09-14-2023 10:36 AM |
use Carbon and Carbon Pre together as one interface in Logic/Cubase ? | pm mastering studio | Pro Tools | Carbon | 0 | 12-22-2022 01:54 AM |
Native Monitoring/recording performance under Carbon? | Ru_C | Pro Tools HDX & HD Native Systems (Mac) | 1 | 08-16-2021 07:36 AM |
Carbon - External Source Monitoring | [email protected] | Pro Tools | Carbon | 5 | 01-29-2021 01:50 PM |
