Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 09-03-2021, 07:23 PM
tomhartman tomhartman is offline
Default Carbon Delay Comp with external hardware?
Does Carbon automatically compensate with both versions of PT, or just Ultimate? Thanks much
Tom
Old 09-04-2021, 07:53 AM
JTC111 JTC111 is offline
Default Re: Carbon Delay Comp with external hardware?
Tom
I believe that both will auto compensate in the box but Ultimate will auto compensate for hardware inserts where with vanilla you'll have to do that manually.
Old 09-04-2021, 08:41 AM
JFreak's Avatar
JFreak JFreak is offline
Hardware Inserts are delay compensated, but you need to enter manually the extra compensation value if for example you know that your reverb takes 2.5ms to process. Most would not care about it with regards to reverbs, it is just extra pre-delay, but for those that want everything to be in perfect order there is a way.
Janne
issues: HDX-2 (PT10) delay comp…. RTAS & hardware inserts MixerGuy Pro Tools 10 8 10-06-2014 03:21 PM
Delay Comp problems again, Delay comp is RED but way below limits. soundeq Pro Tools TDM Systems (Mac) 13 11-29-2011 12:01 PM
Hardware Insert Delay Comp Issue therecordinghouse Pro Tools 9 7 11-17-2010 06:01 AM
Hardware delay comp blackbirdstudio Pro Tools TDM Systems (Mac) 1 01-03-2010 09:35 AM
How to use external hardware comp?? TDub 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 10-25-2009 04:29 AM
