Old 03-31-2021, 08:34 AM
Howardk Howardk is offline
Default Modern Interrupts
What do we make of this from the release notes? My hope is this will resolve some of the performance issues and AAE Errors/halts. Thoughts?
“ HD Device Improvements
In order to support Big Sur, Pro Tools and the HD Driver have been updated to use modern interrupts (MSI). This change may also prevent or minimize conflicts with other PCIe devices on any supported operating systems.
This requires a firmware update for both HDX and HD Native. This firmware is backward compatible with earlier versions of Pro Tools and HD drivers.”
...for system configuration info see my profile
(Click on member name)
Old 03-31-2021, 09:09 AM
daeron80 daeron80 is offline
Default Re: Modern Interrupts
Apparently, by "modern," they mean approximately since the Bush administration. PCI added support for MSI in 1998. Windows added support with the release of the Vista OS in 2006. I guess Avid figures 16 years is long enough that they should add support for it.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 03-31-2021, 09:48 AM
nebosphere nebosphere is offline
Hoping this will make large sessions with a lot of uad plug-ins while using the hdx engine work better at low latency. Verdict is still out. I’m running a UAD Octo card in a sonnet chassis along with the hdx.
Would love to know if anyone else has noticed any improvement! It was especially bad with high usage plugins like UAD Fender amp sims.
Old 04-01-2021, 03:50 AM
HenrikUdd HenrikUdd is offline
I'm running HDX with Octo card in Sonnet chassi on Imac Mojave. This version of Pro Tools is the best I've ever used on this system. I was dealing with a very slow project, not really maxed out the UAD but with heavy load and it was constantly stopping my playback whenever there was automation coming in. Hardly couldn't play the session. Updated and after that the system usage was around 43% (didn't check what it was before but obviously spiking a lot) its been like cutting thru butter, haven't had a single playback stop and not a single pro tools crash. Whatever they did it's amazing for me. Like I've bought a totally new computer. Haven't felt this great since 2008 haha! Although the firmware update didnt go well the first time around, but managed to finish it on the second attempt. Not being able to double click folders in import dialog boxes is a bit annoying on Mojave as well, but other than that absolutely brilliant update
Old 04-01-2021, 06:23 AM
That's great to hear! I'm going to do more testing on this today/tomorrow.
Old 04-01-2021, 12:04 PM
Hope it works just as well for you
An old MC Control in a modern world GreenWire Artist Series 4 09-01-2018 04:05 PM
Modern archive solutions EarHole Post - Surround - Video 5 08-08-2014 01:02 PM
Modern alternative to 002 the_dr38 Pro Tools 11 4 07-23-2014 06:24 PM
Modern Beats Justin75654 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-15-2009 04:56 PM
Compatability of 001 with modern pc's ruben74 General Discussion 1 10-14-2003 06:56 PM
