Old 09-01-2014, 06:18 PM
Tassoul Tassoul is offline
Default Error message CPU too slow (AAE-9173)
Just got mac osx im running 16gb with a terabyte drive and Im getting this error message telling me to de-activate or remove native plug-ins Im using. Is there a setting in preferences or something Im missing? Is there any solution to this issue.
Please help
Thanks
Old 09-01-2014, 06:33 PM
Southsidemusic's Avatar
Default Re: Error message CPU too slow (AAE-9173)
Welcome to the Community
Start by reading this and re-post what we need regarding your system and setup to be able to help you.
http://duc.avid.com/showthread.php?t=300050
Christopher
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 09-01-2014, 07:46 PM
CygnusX-1Bk2 CygnusX-1Bk2 is offline
There is another thread on this issue. Two actually.
http://duc.avid.com/showthread.php?t=357286
I will choose,
Freewill
http://jimdiazaudio.com/
Old 09-01-2014, 09:29 PM
fmilian's Avatar
fmilian fmilian is offline
I got those errors when my card was inserted on wrong PCI-X. Not your case.
I goes you are using a firewire or usb audio card. are you using an internal firewire/usb port or an adapter (PCI-X to Firewire/usb, or something else) ? Did you had some other device installed on that port?
Try to use the port that is onboard, on the mainboard, not with a bracket...
Florin Milian
OS X 10.9 / Mac Pro Early 2009 / 12GB Ram / Protools HD 11 with HD Omni/Native Core.
PC Intel Quad Core / Protools LE 8.0.3 / Digi Rack 003+ / Win7-64
Old 09-02-2014, 08:24 AM
sw rec sw rec is offline
If you're trying to do this with a single hard drive (you stated A-as in one-terabyte hard drive) you're just asking for all kinds of errors. You need a dedicated secondary hard drive. From the MAC troubleshooting page:
http://duc.avid.com/showthread.php?t=54888
IMPORTANT! You MUST use a secondary hard drive (not your main OS drive) for recording and playback of audio in Pro Tools. Recording or playback from the OS drive is known to be problematic and the cause of many different error types. If you are using your system drive and encountering errors, the first thing you should do is get a compatible drive.
Pro Tools supports recording and playback to a secondary drive that meets the following requirements:
7200 rpm or faster
9ms seek time or faster
Please note that this has nothing to do with how LARGE the drive is. You STILL need a secondary drive if you want this to work correctly.
Pro Tools 11.1.0 AAE-9173 Error justus1900 Pro Tools 11 4 12-22-2015 02:46 PM
11.2.1 My Findings, -9173 error with BTD Intransit Pro Tools 11 77 11-23-2014 04:12 PM
Aae-9173 txrx Pro Tools 11 5 12-28-2013 04:34 PM
Error Message: disk is too slow or fragmented????? Animal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 04-19-2004 09:25 AM
disk too slow error message jerkcrap 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-15-2003 03:26 PM
