Old 04-28-2011, 11:41 AM
Chris Townsend Chris Townsend is offline
Lightbulb Blog: Modern Plexi
I just posted a new blog (with presets) about how to get a more "modern" Plexi tone using the RB-01b Blue channel, kind of along the lines of some of the various modded circuits out there.
http://community.avid.com/blogs/avid...ern-plexi.aspx
Chris Townsend
Guitar Products Architect
Digidesign, A Division of Avid, Inc.
Old 04-29-2011, 06:31 AM
DAR Fritz DAR Fritz is offline
Default Re: Blog: Modern Plexi
Thnxs for the pre-sets Chris. Love the tones with my Strat!!
Old 04-29-2011, 06:37 AM
ratter ratter is offline
Chris I believe you mentioned in the past that the Boost control on the RB corresponds to different boost/excursion/whatever settings on the amp you modelled. Can you post anymore detail about that?
Old 04-29-2011, 10:09 AM
Ratter, here are the details from the ERXP Read Me:
Boost Simulates the Boost and Structure switches on the original amp. Setting Boost to 10 simulates both Boost and Structure switches on. A setting of 5 simulates Boost on/Structure off. A setting of 0 simulates both switches off.
And here's a link to the Read Me pdf:
Eleven Rack Expansion Pack Read Me (v2.0.1)
Chris Townsend
Old 04-30-2011, 05:19 AM
bredo bredo is offline
Ah, you meen a PleXTC (that's my amp name) or Plexstacy (free on the market)
Old 05-01-2011, 06:18 PM
The Whale The Whale is offline
Chris - These rigs sound excellent! I'm not quite sure what the Para EQ's are doing... seems as though there's a very small low end roll-off around 80hz, but where's the treble adjustment?
Either way, sounds great and I'm enjoying having a plexi rig without the swirl! :)
Peace,
Mike
Old 05-02-2011, 10:54 PM
Whale, glad that worked for you. The Modern Plexi VH has the bright filter set flat because that's what happens when the gain is dimed on a real Plexi. The Modern Plexi Crunch has less gain, and band four of the Para EQ has some treble boost to account for this bright filter.
Chris Townsend
Old 05-07-2011, 11:34 AM
Benoni's Avatar
Benoni Benoni is offline
You can hear the real XTC's Plexi tone (and other channels) here if anyone wants to compare or 'model' a Rig from the real tone.
Ecstasy 20th Anniversary
Plexi mode, clean, 4x12 GB25's, 60's Custom Shop Strat
Plexi mode, cranked, 4x12 GB25's, 60's Custom Shop Strat
Plexi mode, Sunface Germanium Fuzz, 4x12 GB25's, 60's Custom Shop Strat
Plexi mode, cranked, 4x12 GB25's, 57 Historic Les Paul
Plexi mode, Sunface Germanium Fuzz, 4x12 GB25's, 57 Historic Les Paul
and here is the RED channel of the 20th Anniversary head
Red channel, 4x12 GB25's, 57 Historic Les Paul
ECSTASY CLASSIC EL34
Plexi mode channel 2, gain turned up, Gibson Historic '57 Gold-Top Les Paul
Plexi mode channel 2, gain turned up, Gibson Historic '57 Gold-Top Les Paul-2
Red high-gain channel running at 3/4 gain, Gibson Historic '57 Gold-Top Les Paul
Clean channel, gain 1/2 turned up, Gibson Historic '57 Gold-Top Les Paul
ECSTASY 101B EL34
Clean channel first then Red channel high gain, Ernie Ball EVH
Clean channel, Strat with stacked pickups
Clean channel, Strat with stacked pickups-2
Blue channel, Strat with stacked pickups
Red channel, Strat with stacked pickups
Red channel, Gibson Historic '57 Gold-Top Les Paul
Red channel, Gibson Historic '57 Gold-Top Les Paul-2
Red channel, Gibson Historic '57 Gold-Top Les Paul-3
Blue Channel Plexi-mode, PRS McCarty
Blue Channel Plexi-mode, PRS McCarty-2
Blue Channel Plexi-mode, PRS McCarty-3
Blue Channel Plexi-mode, PRS McCarty-4
Blue Channel Plexi-mode, Gibson Historic '57 Gold-Top Les Paul
Blue Channel Plexi-mode, Gibson Historic '57 Gold-Top Les Paul-2
Blue Channel Plexi-mode, Gibson Historic '57 Gold-Top Les Paul-3
ECSTASY 101A 6L6
Clean Channel, Funky groove, Tom Anderson Drop Top Classic neck pickup
Clean Channel, Funky groove, Tom Anderson Drop Top Classic neck pickup-2
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 05-08-2011, 07:17 PM
singtall singtall is offline
i tried the modern plexi preset and cranked the gain some. awesome! i found that it does the King's X tone easily, along with just about anything else i ever wanted.
thanks man, this is the sh*t!
Old 05-08-2011, 11:23 PM
Awesome, glad you like it.
Chris Townsend
11R Plexi - now with more Deep Purple! adamqlw Eleven Rack 8 03-17-2015 12:39 PM
Eleven Rack Plexi Demo Jd0g33 Eleven Rack 11 05-01-2011 07:53 PM
My Eleven Rack arrived on Friday..Stuck on Plexi Model! jimification Eleven Rack 12 11-02-2010 09:49 AM
Modern Beats Justin75654 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-15-2009 04:56 PM
Compatability of 001 with modern pc's ruben74 General Discussion 1 10-14-2003 06:56 PM
