Old 07-30-2009, 06:54 AM
paul_g paul_g is offline
Default Sends Inactive w/ Low Latency Monitoring
[Factory 003&PT 8 LE]
Why are are sends disabled when low latency monitoring is enabled?
I'm taking a bunch of tracks and just sending them to output's 3&4 on the factory 003 with no effects/plugs enabled, so why would sends be disabled?
What is the work around?
1. Can I disable low latency monitoring and experience no latency if I:
a. disable all plugs
b. set hw buffer size low - i.e. 128 or 64
c. all of the above
Need some help here. I want to be able to do headphone mixes - one for the drummer one for the rest of the band, and was going to use sends on all tracks to outs 3&4 (cause sends can be Pre-fader and have their own levels). Out's 3&4 go to a headphone distribution amp.
In theory this works... except when I record enable the tracks only to find the sends are disabled! Ughhh... any suggestions would be appreciated.
pg
5K Retina 27" (2020) iMac OS 15.3 Sequoia
3.3 GHz 6-Core intel Core i5
AMD Radeon Pro 5300 4 GB
64 GB 2667 MHz DDR 4
Internal 2TiB SSD
Pro Tools 2024.10.2
EuCon 4.8.6.41 / 2024.10.0.19
UA Luna
UAD 11.5.2
UA Apollo Twin X
Avid S1 / Fire10 - 21.8.1.0
PreSonus DigiMax FS 8-input ADAT
Dynaudio Monitors
PreSonus Temblor 10 Sub
Check my Music out here:
Paul G YouTube
Paul G Bandcamp
Old 07-30-2009, 07:00 AM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Default Re: Sends Inactive w/ Low Latency Monitoring
if u set ur buffer rate low then of course u don't need Low Latency mon. but yes when u do use it any thing that is on a track in record mode will go into bypass mode hence Low Latency mon...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 07-30-2009, 07:17 AM
I agree with KB. Set your buffer at 64 for initial tracking(keep plugins to the bare minimum at first). I do a variation of what you are trying for. I feed the main mix to the headphone amp(Behringer HA4700). Since it has an aux input to each of the 4 sections, my 4 players can each have "more me" with a single(mono) send for each player.
Old 07-30-2009, 03:46 PM
Thanks guy's - I'll use 64 for tracking w/no plugs.
p
Internal 2TiB SSD
Pro Tools 2024.10.2
UA Luna
UAD 11.5.2
UA Apollo Twin X
Dynaudio Monitors
Paul G YouTube
Paul G Bandcamp
Will making inessential tracks inactive help reduce latency while recording? Pete Rickards Pro Tools 11 5 09-01-2013 08:44 PM
Some outputs and sends were made inactive? ZombiesAreJerks macOS 1 04-27-2013 04:26 PM
Plug In's Inactive and Low Latency Message Room335 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-07-2008 05:28 AM
Describe your studio monitoring sends setup starburst 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-03-2007 10:56 AM
Monitoring record enabled tracks via sends Animal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-17-2004 04:03 PM
