At our post-production facility we've found that the PPM metering offered by SignalTools is reading quite significantly lower with quick transients than when using PPM metering on Chromatec hardware meters. This could obviously result in tech review failures if relied upon for dubbing.
We're suprised this is the case and we were wondering if Digidesign had the meters approved from the BBC before releasing them? Dan |
From what I can see, this has been logged as a bug and is being looked into.
Well, we've been testing it here and it's reacting EXACTLY the same as our DK Audio MSD600M++ on BBC scale........which is fed digitally from a 192.
Simon Jones Freelance sound creative. Bristol / Cardiff, UK Re-recording mixer specialising in TV drama. Mac Studio M2 Ultra 64gbRAM Focusrite Red16 line, Pro Tools Ultimate 2023.6 |
Sad person that I am, I have a PT session with the appropriate burst tone tests that test the dynamic signal performance for the BBC PPM. So I ran a series of tests with the PPMulator VST plug-in with FXpansions VST to RTAS wrapper and the Digideign SignalTools meter on the BBC preset.
All tests done with a 10kHz sine wave at +8dBu (PPM6) as per the spec. Undertaken on a Dual 1.42Gig G4 with Pro Tools 7.1 software with HD2Accel and 192 interface. burst duration - 100ms spec +8dBu tolerance +-0.5dB PPMulator +7.5dB SignalTools +7.5dB burst duration - 10ms spec +6dBu tolerance +-0.5dB PPMulator +6.0dB SignalTools +3.0dB burst duration - 5ms spec +4dBu tolerance +-0.75dB PPMulator +4.5dB SignalTools -0.5dB burst duration - 1.5ms spec -1dBu tolerance +-1.0dB PPMulator -2.0dB SignalTools -9.0dB burst duration - 0.5ms spec -9dBu tolerance +-2.0dB PPMulator -10dB SignalTools -13dB So you can see from this data that the SignalTools PPM definitely doesn't meet the BBC or EBU spec for a PPM but the PPMulator plug-in does! Hope that helps, |
SignalTools | awe | Post - Surround - Video | 1 | 05-03-2012 07:40 PM |
Signaltools | SZE | Post - Surround - Video | 1 | 10-22-2010 05:55 AM |
SignalTools - Big CPU hit! | ricren | Post - Surround - Video | 7 | 08-30-2006 12:09 PM |
Will Signaltools with with 6.7 or 6.9? | rlcowa@work2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-12-2006 08:14 AM |
Signaltools Bug | moojiefulagin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 08-09-2006 06:31 PM |
