Old 08-02-2006, 07:12 PM
ricren ricren is offline
Default SignalTools - Big CPU hit!
I was waiting for this plug-in because I could really use good “in–the-box” meters. Since Spectrafoo is not longer available as a plug-in in OSX, there’s a void on this department. I really miss the possibility of customize every detail of a meter, like size, scale, colors, you name it.
So I downloaded the plug and I tested it briefly.
The good: is free.
The bad: Big CPU hog. I tested the RTAS version on this Macbook 2.0-2Gig Ram + PT 7.1.1. With a single “phase scope” instance and its window open, in a small session PT becomes very sluggish and the display is a bit jerky. (Not good on meters).
Strangely, the CPU meter inside PT only shows a modest hit (less than 1/5 of scale), but Activity Monitor shows that with the plug-in loaded the machine CPU utilization jumps from 20% to almost 100%, regardless of the setting in the “playback engine” window. Weird.
I could not test it in TDM (still in 6.9.1) so things could be different there.
Ric
Old 08-03-2006, 10:58 AM
JanuS JanuS is offline
Default Re: SignalTools - Big CPU hit!
Hmmmm.. I wish I could confirm or deny your foundings, but I'll get an installation error when I want to
install the Signal Tools (HD2 PT 7.1cs7 G5 2.0)
Digi? Is this just the first batch, or could there be more (me?)
Old 08-03-2006, 11:05 AM
Aquarius Aquarius is offline
So what's the deal in TDM ?
I'm curious if set to compare to Dolby LM100 (LeqA)
Cheers,
A
Old 08-03-2006, 11:07 AM
Not here. Dual 2.5Ghz G5. No increased CPU-load. Although the scope reacts so slow it´s far inferior to a hardware scope.
Frank.
PTHDnPCIe 2024.3.1 (OSX13.6.7), 8x8x8, MacPro 14,8, Decklink SDI 4k, SYNC HD, Nanosyncs HD, 64GB RAM, Xilica Neutrino, Meyersound Acheron
Old 08-03-2006, 01:08 PM
The CPU hit is so big that I wonder if this package is UB. May be not. That could explain it.
Ric
Old 08-03-2006, 03:46 PM
jimlongo's Avatar
jimlongo jimlongo is offline
In a fair sized session with video I experience little CPU hit, but half a HDCore chip.
UPDATE: I just tried it as RTAS, it seems to react the same (except that of course no DSP hit)
Dual2.0G5 / 3GB ram / 7.2
noise | jimlongo
Old 08-30-2006, 09:38 AM
Kirkland Kirkland is offline
Click on "compatibility" in the Signatools section and you'll see that the very first line says "Not yet compatible with Intel Macs". You're running that plug under Rosetta which would explain the steep CPU usage...
Old 08-30-2006, 12:09 PM
1150Post 1150Post is offline
Bingo... Signal Tools is a No-Go for Intel Mac. My guess would be that the Intel Update for Intel will probably coincide with the Intel 7.2 TDM release.
Brad McIlvaine
Sr. Mixer/Designer
Henninger Media Services
Washington, DC 20036
HTML code is On
SignalTools awe Post - Surround - Video 1 05-03-2012 07:40 PM
Signaltools SZE Post - Surround - Video 1 10-22-2010 05:55 AM
SignalTools PPM issues Dan Lyth Post - Surround - Video 3 09-03-2006 09:12 AM
Will Signaltools with with 6.7 or 6.9? rlcowa@work2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-12-2006 08:14 AM
Signaltools Bug moojiefulagin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-09-2006 06:31 PM
