Old 03-04-2023, 02:50 PM
johnnyv johnnyv is offline
Default How do you follow clip naming conventions:
Hi guys, I'm wondering how most of you follow clip naming conventions when doing ADR. Do you
1. Change the track name each time you come to the next line to record so that the clip name ends up proper?
2. Set up multiple tracks pre-named so that you record the first ADR line records on the first track, then you disarm that track and arm the next track?
3. Do all the naming after the session is over?
Thoughts? Is there a generally accepted method?
Thanks for your thoughts!
John
Old 03-04-2023, 08:09 PM
audiolex1 audiolex1 is offline
Default Re: How do you follow clip naming conventions:
John
4. Get Edicue and EdiPrompt. They do it automatically in any kind of configuration you want.
https://www.soundsinsync.com
Mac Pro 5,1. 3.46 12 core, 128 gigs ram, 580 GPU flashed Apple EMI, 3 monitors
PT Ult 2023.6, OSX 10.14.6, 3 card PCI-e expansion with 3.2 USB Sonnet card.
OCTO 8 card, Apollo 8 Quad, UAD quad satellite FW.
Almost every plugin
Old 03-04-2023, 10:20 PM
Thank you for that! We actually have that software but haven't done enough ADR to put it to use (we more often record singing). Will check that out before the session!
Thank you!
Old 03-05-2023, 07:25 AM
smurfyou smurfyou is offline
If you have access to EdiPrompt check it out. Sounds in Sync might have a tutorial but you should also run a mock practice session to get to grips with it. Not hard, just need to see how it works. It will take care of renaming the record track for you.
I like to have a track for selects, two tracks for alts, and maybe a couple for editing. In addition to the record track(s). Plus your guides, beeps, etc...
~Will
Old 03-05-2023, 04:12 PM
Will, thanks for that. Yes, we do have it but just haven't had the occasion to delve into it. But will DEF check it out!
J
HTML code is On
Clip Naming Workflow Problem fieldnoise macOS 1 07-11-2021 04:42 PM
Importing clips in Pro Tools 10 / clip naming legasafe Post - Surround - Video 3 10-20-2012 05:44 AM
Clip naming dannymeltzer macOS 0 12-02-2011 02:30 AM
Track naming conventions lets talk.... djd2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-16-2006 11:34 AM
Takes List Naming COnventions ronstephens 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-01-2005 01:06 PM
