New update changing H/W buffer size?
I've noticed my H/W buffer size changing from 1024 to 256 a few times since the update. I can't really pinpoint it to what else it could be. I've only been doing mixing and my buffer will always be at 1024, so 256 is odd. Just wondered if anyone else has run into this.
Re: New update changing H/W buffer size?
What is your hardware (audio interface)?
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
Focusrite Saffire Pro 24 DSP. I am on macOS High Sierra, which is now dropped, but this and the last update were working fine otherwise.
Try resetting your nvram/pram on startup - that might help. To do that hold down the cmd/option/P/R keys when you start the computer and hold them down until you hear the second startup chime. That sometimes helps with oddities.
Hi.
Working with 1024 buffers It's okay to change to 512 buffers. However, if you save with 512 buffers, you will not be able to play it when you restart the session. Mac Pro (2019) 3.2 GHz 16-Core Intel Xeon W 96 GB 2933 MHz DDR4 |
Huh?
Thanks. I will try that.
Maybe you misunderstand. When I load a session with a current buffer of 1024, PT changes it to 256 by itself.
PT 12.7.1 changing buffer size crash PT | Kirito | Pro Tools 12 | 7 | 07-14-2017 02:28 PM |
Changing buffer size to open PT 11, help! | cronix | Pro Tools 11 | 4 | 01-30-2015 05:24 PM |
11.2.2 hangs on changing buffer size | VRW | macOS | 4 | 12-15-2014 05:46 PM |
10.1.2 Crash when changing Buffer Size | Erik318 | Pro Tools 10 | 3 | 11-14-2012 06:49 AM |
Changing Buffer Size | GarthVader | Pro Tools 9 | 2 | 12-02-2010 12:52 PM |
