Old 08-22-2006, 01:47 AM
Courvo Courvo is offline
Default Speaker output
'Almost embarrassed to make this post, but I have been through the manuals, and can't find anything close to an answer.
I use M-Powered Pro-Tools 7.1, and my interface is the M-Audio Firewire Solo.
How do I route my output to studio monitors? All I get now is output through my headphones. 'Have checked the I/O settings in "Setup" menu, but only the FW>Solo shows for input and output.
Apologies for what I'm sure must be an elementary issue for all you pro's here.
Dave C. in Las Vegas
Old 08-22-2006, 08:22 AM
cemastering cemastering is offline
Default Re: Speaker output
Hi Dave,
Are your studio monitors powered? If not, you'll need an amp to power them - then hook up the 'balanced line outputs' of your m-audio interface to the inputs of your amplifier. This should do the trick!
Make sure that Pro Tools knows to output the audio to the stereo out of your m-audio interface - it sounds like it does, as you have sound through your headphones.
mbox 3 system output only right speaker e_man FireWire & USB Audio Interfaces (Mac) 1 02-19-2014 06:53 PM
Speaker Output weirdness Baritonealone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-29-2008 05:04 PM
Output from PTLE 6.4 to Mac speaker output AndyA1979 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-29-2007 08:29 PM
Only getting output from the left speaker Bus 7-8 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-09-2004 07:00 PM
Speaker Output Level from the 001 box -- i have it maxed out..... peter parker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-21-2002 06:43 PM
