#21
Re: Monterey 12.3.1 Update
macOS 12.3 is available from Apple. There is a security issue that was fixed via macOS 12.3.1, so I suggest you get that update instead.
On your Mac, simply click on the Apple icon in the upper left of the screen, select "About This Mac," and then click on the "Software Update..." button to bring up the software update dialog box.
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 Last edited by Obsidian Dragon; 04-08-2022 at 02:30 PM. |
#22
Just updated to 12.3.1 and Pro Tools Ultimate 2021.12.0. I am no longer able to access the AudioSuite function (all grayed out). Anyone seeing this or have a solution?
#23
I made it 12.3.1. No problem. When removing the drawing bug and send of VCA from the insert, the drawing collapses, but the operation is comfortable. |
#24
Did you upgrade from Monterey 12.3 to 12.3.1? If you upgraded from an earlier version of macOS like Big Sur or Catalina, it might be that your plugins have not been updated to version 2022.2 which is what is needed to be compatible with Monterey. Check your Avid account or Avid Link to see if they have an update. For me, all the plugins that worked in Monterey 12.3 also work in Monterey 12.3.1
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 Last edited by Obsidian Dragon; 04-03-2022 at 06:18 PM. |
#25
Scott Gatteño |
#26
Ben, does this mean that on M1 machines you can not clone your internal drive onto an external and boot up from there anymore? I wasn't aware of this.
#27
Yep I'm using an M1 Macbook with 12.3.1 and it's working fine no problems. I'm using Waves and Avid plugs.
#28
I use Carbon Copy Cloner, and I have a bootable clone of my internal drive on an external. It's not as easy as before, but CCC has a feature that makes it easier. But again, there are serious limitations compared to before. Lots of info on the Bombich site: Frequently asked questions about CCC and macOS 11 (and later OSes) Apparently the problem is with upgrading the system. I haven't gone there yet, so I'll not try to pretend I know all about it. (BTW, this really has nothing to do with SIP like I wrote so strike that. I got confused.) IHTH.
#29
Everything Ben wrote is correct. But, your question was asking about M1 Macs. This is NOT specific to M1 Macs. It is the same for Intel based Macs as well. Worth clarifying that point. Also, this started with macOS Catalina. Sent from my iPhone using Tapatalk |
#30
I beg to differ. I used Catalina for over a year, and cloned and imaged my boot drive the old way with no problem. "Signed System Volume", which it's called, came with MacOS 11 Big Sur.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. Last edited by Ben Jenssen; 04-07-2022 at 02:02 AM. Reason: Of course I did not run Catalina on M1. Corrected. |
Age old question: what to do about AIR plugins (Monterey update) | moshuajusic | Pro Tools | 3 | 06-24-2022 10:25 PM |
Macros in Monterey | thin ice | macOS | 0 | 03-11-2022 03:37 AM |
Monterey Compatibility | ReynaldoPena | Pro Tools | 33 | 03-08-2022 07:29 AM |
Monterey is now available | Obsidian Dragon | macOS | 80 | 02-05-2022 10:52 AM |
Monterey IOS | rjbee | Pro Tools | Intro Discussion | 1 | 11-25-2021 10:59 AM |
