Exporting Album
I have a 30min recording that I want to export into 6 separate tracks with no gaps between in playback for release on/via Avidplay,,, can I do this within protools or do I have to use something like studio one?
Thanx |
Exporting Album
Split the file into clips where you want the seperate tracks to appear. Then in the clip list, select export clips as files. This will render them as seperate audio files to wherever you choose to save them.
Couple of things though. Any processing you have inserted will NOT get rendered. If you have plugins on the track, you’ll need to bounce to disk each clip. Another thing to be aware of, if you’re converting to a lossy medium like MP3, the files will not be gapless and you will hear a very small pause/hiccup as it goes from one track to the other. This won’t happen on WAV files, but it will with MP3. Sent from my iPhone using Tapatalk |
Re: Exporting Album
And Sardi is correct about mp3s. There's no way to avoid forty-some millisecond gaps. It's an inevitable consequence of the windowing method in the 30-year old design of that obsolete format. I have no idea what formats Avid Play allows. But avoid mp3 if at all possible.
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
First BIG 001 album? | scardanelli | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 02-13-2003 09:07 AM |
Help needed with DJ mix album | Olly J | Pro Tools TDM Systems (Mac) | 3 | 11-17-2002 03:24 AM |
The Album Is Out! | valvebrother | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 14 | 08-30-2002 12:51 AM |
Looking for someone to mix an album in DC | spong | Pro Tools TDM Systems (Mac) | 3 | 04-26-2002 08:03 AM |
About to mix my first ALBUM... | Mr Peete | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 04-19-2002 04:23 AM |
