Disk REALLY slow to ramp up to record
Yesterday's session was plagued by problems with my disks taking 4-5 seconds to go into record over 6-8 tracks. Since buying my MixPlus system (G4/350/192RAM/ATTO PSC 1.4.4f/Cheetah/Ultrastar drives) I've always kept the record allocation to OPEN ENDED and have been able to record on 1-24 tracks with about a 0-1second wait before going into record.
Today's troubleshooting revealed the following: 1. Internal ATA drive went into record on 8 tracks 3 times as fast as Ultrastar 10K SCSI drive (Mac is completely compato-ready and settings are ideal) 2. Recording to FireWire VST 40GB took the same ramp-up time as SCSI disk, just as a test. I don't normally use this for audio. 3. Reducing allocation to 30 minutes or so resulted in WAY faster response. On any disk (SCSI/FW/ATA internal). 4. DAE buffer setting didn't make much of a difference. I've never had this problem in the past year. Could the ATTO EPT have something to do w/ it? The obvious answer is that Yes, limiting recording to a 30-60 minute max will result in better response, but It's never been an issue. Any ideas? |
Re: Disk REALLY slow to ramp up to record
Found this on a search from our man Steve:
______________ Yes, HFS+ is supported with 5.0. You will notice a delay when the Pro Tools primes for recording (the period of time between hitting Record and the drives actually begining to write data). This is a consequence of having to account for the increased number of allocation blocks under HFS+. There is a preference that allows you to preallocate less space than the whole drive, which will speed up record priming. There is no delay associated with playback. ------------------ --Steve Rosenthal, Digidesign ETS ______________________ I think I might reformat HFS. Since reformatting in EPT, I DID do HFS+, so I think this is the answer... |
Disk way too slow? 40 tracks to record | Rockman413 | Pro Tools 10 | 8 | 04-30-2012 01:37 AM |
How do I ramp up pitch? | quadra605 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-15-2003 06:51 PM |
disk to slow (maxtor disk) help! | nossnevs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 05-07-2002 12:05 AM |
Audio Speed Ramp | shawnyashar | Tips & Tricks | 4 | 06-05-2000 08:41 AM |
Cannot bounce to disk-- disk to slow or fragmented? | uno1234 | Pro Tools TDM Systems (Mac) | 4 | 11-23-1999 12:23 AM |
