SC48 to JoeCo or Allen&Heath ICE-16 over Firewire
I have a customer wanting to use a JoeCo recorder or the Allen & Heath ICE-16 recorder with his SC48 by using Firewire. Is this something that can be done?
Re: SC48 to JoeCo or Allen&Heath ICE-16 over Firewire
No!
FWx is just for computers with Pro Tools! The ICE-16 uses Firewire for working as an audio interface, besides being a stand alone recorder. The JoeCo doesn't even have a firewire connection, it's just a stand alone recorder. Regards, MJ |
Any suggestions on the best way to interface a JoeCo box with an SC48?
If it's a Mix Rack, Profile or D-Show, you can use the Venue MADI Option Card and record 64 channels direct to a JoeCo BBR64-MADI, I guess.
If it's a SC48, you are limited to the 32 channels of the FWx interface (using a computer instead of a JoeCo BlackBox). OR, you could connect the SC48 to a JoeCo via analog or AES/EBU, supposing you have the required output modules on the SC48 and the corresponding JoeCo model. But then, you would be limited to 24 channels, maybe FWx could be a better option... Good luck. Regards, MJ |
Allen and Heath ZED 24 | mrjames | Pro Tools 10 | 3 | 05-03-2012 02:23 PM |
allen heath mix wizards? | joeyh | General Discussion | 0 | 10-30-2003 10:06 PM |
allen and heath gs 3 | mersisblue | Tips & Tricks | 6 | 09-01-2003 08:50 PM |
Allen & Heath GS2 with 001 | Keith Lowdon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-19-2002 09:51 AM |
Mackie or Allen & Heath | Jamble | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 12-18-2001 08:01 PM |
