Digi 001 driver corrupted or missing? Help!
Hey gang,
I just put together an upgraded system with an Asus A7V600 mobo. I did a fresh installation of XP with SP1, and everything went fine until I installed the 001 card and tried to install Pro Tools 6.1. The installation finished, but in the Device Manager the 001 is showing as having a problem. It says the driver is corrupted or missing, and PT won't start since it's not seeing the hardware properly. I have the 001 card in PCI slot 3 in the A7V600. Anyone have any ideas to help me out? |
Re: Digi 001 driver corrupted or missing? Help!
I'd uninstall PTLE - pull the PCI card - re-boot, do a search for "Dalwdm" without quotes, and delete any SYS or INF files that are found.
Switch PCI slots - (try 4) boot into bios - load default settings - and try your luck again. Good luck
David - MacStudio M1 - HDX II Sonnet xMacStudio - 16x16 HD i/o x 6 - PT ULTIMATE - SONOMA - ProTools Dock / S1 / Control App |
Hi David,
Thanks for the response. I think I just fixed it, it was a known issue in the Answerbase that if you disable USB in the BIOS this happens. |
Ahhh excellent !
Happy Recording !!
Mbox and ProTools 8.0 - missing driver? | Rydahl | Pro Tools M-Powered (Mac) | 2 | 09-13-2010 12:17 PM |
"missing" / corrupted audio, unreadable by protools 8 PLEASE HELP | daneppel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-29-2010 09:59 AM |
Save Session Copy In corrupted files : Digi please help ! | Aquarius | Pro Tools TDM Systems (Mac) | 1 | 05-28-2008 03:43 AM |
Possible corrupted driver for Digi 001 | Sf Audio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-15-2004 08:55 AM |
Bug in Digi Core Audio Driver? Driver update coming? | mgbasinski | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-10-2003 08:59 PM |
