Protools 12.4 Freezes when Idle on Win7 , Focusrite Scarlett 18i20 USB
PT 12.4
Win 7 Pro Focusrite Scarlett 18i20 USB No screen saver, No drive sleep, all USB hubs Power Mgmt set to keep on. If I leave a session open for an hour or more and let sit idle, and usually I'll turn AOC 27" hdmi monitor off while idle, I'll come back and the session window has been resized to a smaller size. And session essentially frozen, sometimes I can close session, but usually I have to kill PT with Task Manager and restart PT. I've tried power cycling the Scarlett, only thing I haven't tried was unplugging, replugging in the USB cable to Scarlett which I read someone did somewhere with a different device. Any ideas? Workgroup : MSHOME Computer Model : ASUS All Series ASUS MB Serial Number : System Ser********** Chassis : Desktop Mainboard : ASUS Z97-A-USB31 Serial Number : 1511591******** BIOS : AMI (OEM) 2801 11/11/2015 Intel vPro : 9.01.25.1005 Total Memory : 15.9GB DIMM DDR3 Processors Processor : Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz (4C 8T 4.2GHz/4.4GHz, 4GHz IMC, 4x 256kB L2, 8MB L3) Socket/Slot : FC LGA1150 Chipset Memory Controller : ASUS Core (Haswell) DRAM Controller 100MHz, 2x 8GB DIMM DDR3 1.6GHz 128-bit, Integrated Graphics Memory Module(s) Memory Module : Crucial BLS8G3D1609DS1S00 8GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-39-12-6) Memory Module : Crucial BLS8G3D1609DS1S00 8GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-24 5-39-12-6) Video System Monitor/Panel : ACR Acer X223W (1680x1050, 22.0") Video Adapter : Intel(R) HD Graphics 4600 (20CU 160SP SM5.0 600MHz/1.25GHz, 512kB L2, 192MB DDR3 1.6GHz 128-bit, Integrated Graphics) Graphics Processor OpenCL GP Processor : Intel(R) HD Graphics 4600 (160SP 20C 600MHz/1.25GHz, 256kB L2, 1.3GB DDR3 1.6GHz 128-bit, Integrated Graphics) Compute Shader Processor : Intel(R) HD Graphics 4600 (160SP 20C 600MHz/1.25GHz, 512kB L2, 192MB DDR3 1.6GHz 128-bit, Integrated Graphics) OpenGL Processor : Intel(R) HD Graphics 4600 (160SP 20C 600MHz/1.25GHz, 512kB L2, 128MB DDR3 1.6GHz 128-bit, Integrated Graphics) Storage Devices Samsung SSD 850 EVO 250GB (250GB, SATA600, SSD, SED) : 233GB (C:) WDC WD10EZEX-00BN5A0 (1TB, SATA600, 3.5", 7200rpm) : 932GB (F:) WDC WD10EZEX-00BN5A0 (1TB, SATA600, 3.5", 7200rpm) : 932GB (G:) TSSTcorp CDDVDW SH-224FB (SATA150, DVD+-RW, CD-RW, 512kB Cache) : N/A (D:) Logical Storage Devices System Reserved : 100MB (NTFS, 4kB) @ Samsung SSD 850 EVO 250GB (250GB, SATA600, SSD, SED) WD1 (F:) : 932GB (NTFS, 4kB) @ WDC WD10EZEX-00BN5A0 (1TB, SATA600, 3.5", 7200rpm) WD2 (G:) : 932GB (NTFS, 4kB) @ WDC WD10EZEX-00BN5A0 (1TB, SATA600, 3.5", 7200rpm) Hard Disk (C:) : 233GB (NTFS, 4kB) @ Samsung SSD 850 EVO 250GB (250GB, SATA600, SSD, SED) Optical Drive (D:) : N/A @ TSSTcorp CDDVDW SH-224FB (SATA150, DVD+-RW, CD-RW, 512kB Cache) Peripherals LPC Hub Controller 1 : ASUS 9 Series Chipset Family Z97 LPC Controller Audio Device : ASUS 9 Series Chipset Family HD Audio Controller Audio Codec : Realtek Semi High Definition Audio Serial Port(s) : 1 Disk Controller : ASUS 9 Series Chipset Family SATA Controller [AHCI Mode] USB Controller 1 : ASUS 9 Series Chipset Family USB xHCI Controller USB Controller 2 : ASUS 9 Series Chipset Family USB EHCI Controller #2 USB Controller 3 : ASUS 9 Series Chipset Family USB EHCI Controller #1 USB Controller 4 : ASUS ASM1142 USB 3.1 Host Controller SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Intel(R) Ethernet Connection (2) I218-V (Ethernet, 100Mbps) Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1) Platform Compliance : x64 |
Re: Protools 12.4 Freezes when Idle on Win7 , Focusrite Scarlett 18i20 USB
FWIW, I never leave a session open for more than 5-10 minutes. My rig is completely different than yours but I still had similar experience. Now, whenever I am going to be away, I save and close the session(leaving PT open). Never had an issue since
BTW, you don't need to turn the monitor off as flatscreens do not suffer screen burn like the old CRT;s did. Turning the screen off is confusing your graphics processor, hence the screen resolution change
Your build looks pretty solid, so I don't think that is causing the issue. Have you done all of the Avid recommended optimizations (Additional Resources at the top of this page)? Again, probably not causing your issue, but a very good idea to do all of the optimizations.
As Albee1952 said, save and close your session when you are going to be away for more than a few minutes. If you do that and still leave PT open, does the freeze still happen?
"Whiskey Bottle...Brand New Car...Oak Tree You're in my Way" RVZ Digi 002 rack , Command 8, Behringer ADA 8000, Tascam M-320B Mixer, Alesis Monitor Two Speakers, Vintage and Modern Tube Amps, Fender American Strat, 1973 Gibson SB-450 Bass, Epiphone Les Paul Traditional Pro, Roland W-30 Keyboard, Preimier XPK Fusion Drum Kit. |
I did have HDMI Audio enabled to the Monitor (which has an audio output jack, but no speakers unfortunately ;(.
This could have been the cause, so I disabled that and will have to try a few more tests with hdmi audio disabled and report back. Ideally, would be nice to know if it's possible to keep hdmi audio to monitor on so we could send windows sound to monitor via HDMI instead of to PT I/O device like Scarlett. I didn't even know speakers in hdmi monitors was a thing - sales guy probably could have upsold me at the time if he had 'em, though with my luck they'd probably end up impacting performance with the PT/Scarlett combo anyway, especially with the sample rate change tango. |
So far not hanging after disabled hdmi audio to monitor.
Focusrite scarlett 18i20 | madselhoff | Third Party Interfaces | 6 | 01-25-2016 04:45 AM |
Pro Tools 11 with Focusrite Scarlett 18i20? | hermonmusic | Third Party Interfaces | 24 | 06-27-2015 08:53 AM |
pro tools 11 stops recording during 96khz sessions with focusrite scarlett 18i20 | ilmetallo | Third Party Interfaces | 11 | 05-28-2015 09:23 AM |
Focusrite Scarlett 18i20 ProTools crash. | BurtonTrucking | Third Party Interfaces | 7 | 04-17-2014 11:30 AM |
Eleven Rack + Focusrite Scarlett 18i20 | eboyer | Eleven Rack | 2 | 03-16-2014 09:51 AM |
