HI, first time poster here. Thanks for you help in advance. I'm running LE 7.4 on a PC and can't see the whole screen. It used to be fine, then changed...prob something I did. Look at the screen shot; left side. Any ideas how to expose the side bar?
Hope you're not on Windows 7 here(7.4 is not compatible). I would try to drag the title bar(the top bar of the window) and drag it left until you can see the 3 little boxes in the upper right corner, and hit the maximize button(the middle of the 3). If that doesn't work, try changing the screen resolution, once you can see the right edge, drag it towards the left, restore the screen resolution and maximize, or drag the edges out to fill the screen.
Gigabyte X79/intel i7 3930K, 32GB RAM, HD/Native, 192 IO https://www.facebook.com/search/top/...0sound%20works The better I drink, the more I mix ![]() BTW, my name is Dave, but most people call me.........................Dave |
Thanks Albee.
Not on 7, running XP. Tried all you suggested, no luck. The problems seems to be in the PT program. I can move the screen around my desk-top, but can't adjust the screen within the PT window. This is what is actually looks like when minimized. ![]() |
Have you tried adjusting your screen's resolution?
Yes, tried every screen resolution setting and no luck. Maybe I need to uninstall and reinstall.
I suggest posting a Sandra report and details on the monitor. I suspect a graphics issue that might be solved with a driver update(but the Sandra will tell us if you have a hardware issue).
Noise from Main Out L (hardware problem?) | adamqlw | Eleven Rack | 3 | 02-06-2011 07:29 PM |
Main control unit fader problem | jackie | ProControl, Control|24, Command|8 | 4 | 10-31-2007 09:30 AM |
Control 24 main monitor out problem | Winterland | ICON & C|24 | 15 | 07-03-2007 08:02 AM |
Main Out Problem on Digi002R | bluesboyiv | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 06-08-2006 02:32 PM |
The main screen in PT isn't showing up? | rightsidefalls | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-01-2004 12:14 PM |
