Old 06-17-2004, 11:28 AM
C Room C Room is offline
Default 002 switch between standalone/PT mode is a problem
I need to switch between the Pro Tools mode and the Stand Alone mode with a ProTools session open in order to audition things routed through mixer for playback. On occasion, I can switch to stand alone and back without a problem, but it's becoming more and more inconsistant. Some times I can toggle between modes a few times, and it will finally work. Other times, it requires a reboot (closing pro tools). I would like to avoid having to create tracks in my sessions to audition the other sources. The firmware was updated a week ago and didn't fix this.
Any thoughts?
thanks
greg
[email protected]
Old 06-17-2004, 11:46 AM
Cyamarin Cyamarin is offline
Default Re: 002 switch between standalone/PT mode is a problem
As far as I know, the Digi 002 is not designed to do this. I'm surprised you've been able to get it to work at all. I've always just created the tracks in the session and left them inactive when I didn't want to use them.
Digi 002 Desktop
Pro Tools LE 6.1.2
1Ghz Powerbook G4
512MB RAM
Mac OS X 10.2.8
160GB LaCie FW drive
888/24 in Standalone mode Jantzen Pro Tools TDM Systems (Mac) 4 04-16-2009 02:38 PM
Digi 002 Standalone mode problem with digital sync UK RAF Tips & Tricks 14 10-20-2005 01:30 PM
888 Standalone mode Siegfried Meier Pro Tools TDM Systems (Mac) 1 06-11-2004 02:20 AM
Digi 001 w/NI Kontakt (Standalone Mode Problem) Earthling 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-06-2004 07:13 AM
Digi 001 w/NI Kontakt (Standalone Mode Problem) Earthling Tips & Tricks 0 02-10-2004 09:34 PM
