Old 06-30-2013, 09:42 AM
Erik318 Erik318 is offline
Default Pro Tools 11 and Focusrite Liquid Saffire 56
Hi!
I just recieved the e-mail from Avid with my free student upgrade to Pro Tools 11. I'm very curious to try it out, but I'm a bit reluctant to mess with my currently working configuration. Right now I'm running Pro Tools 10.2 with a Focusrite Liquid Saffire 56 audio interface.
So, anyone out there running PT 11 with the Liquid Saffire 56? Does PT 11 work well with the Focusrite Mix Control software? Is it stable? Should I take the plunge or wait a while?
Thank you for your help
Old 06-30-2013, 10:24 AM
Raggi Raggi is offline
Default Re: Pro Tools 11 and Focusrite Liquid Saffire 56
HI.
Yes, I have both Liquid 56 and 24 and they work well.
Old 07-01-2013, 03:11 AM
Thank you!
Do you know what the proper uninstall/install order would be? I'll need to install the new iLok License Manager as well (hoping it is stable by now). And I might need to update the Mix Control software also (I'm on 3.0 but I see that there is a new 3.2 version available).
So would it be safe to do everything in this order:
1. Uninstall everything related to Pace, the old Pace drivers etc.
2. Install the new iLok License Manager
3. Download the PT 11/10 bundled license onto the iLok
4. Check to see if PT 10.2 is still running fine as usual (in case there is a problem with the new iLok software)
5. Turn off interface
6. Uninstall PT 10.2
7. Uninstall Mix Control 3.0
8. Install Mix Control 3.2
9. Install PT 10.3.6
10. Install PT 11
11. Turn on interface
Does this look ok? Have I forgotten anything? I don't want to risk anything by installing things in the wrong order.
Old 07-01-2013, 04:07 AM
HI.
You should do a full harddrive backup first using Ghost or Drive Image of some sort, just in case you need to revert.
I installed the latest version of PT10.3.6 std installer.
Then I installed PT11, registered with Ilok and everything worked.
Maybe you should install the Mix controll 3.2 first.
Old 07-03-2013, 07:55 AM
Seems to be working great so far! I've been running a session all day now in 11.0.1 with no problems whatsoever. Installation was smooth as well :)
Seems like a stable release
Focusrite Liquid Saffire 56 muzicmaken Pro Tools 10 0 03-31-2012 10:17 PM
Focusrite Liquid Saffire 56 YYR123 Pro Tools TDM Systems (Win) 7 11-16-2011 12:57 PM
Focusrite Liquid Saffire 56 YYR123 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-12-2011 12:31 PM
Focusrite Liquid Saffire 56 and PT 9 ? trock Pro Tools 9 5 09-19-2011 05:27 PM
Pro Tools 9 with focusrite liquid saffire 56 problems johanonsydow Pro Tools 9 24 02-18-2011 07:21 AM
