Old 02-24-2008, 06:46 PM
Avianer Avianer is offline
Default Can\'t seem to fill up my tracks
When I record, i feel like the song feels empty. It doesn't feel full. I've even tried adding thick pads in the song. still not cutting it. Also, any tips on how to make my guitar sound better? I have an option of using a Shure SM57 or a Audix i5 on a Peavey Classic 30 with a strat. I'm just recording stuff for my church record.
Old 02-24-2008, 08:40 PM
albee1952 albee1952 is online now
Default Re: Can\'t seem to fill up my tracks
A few ideas to try: play each track twice(doubling) and use each mic on one of the two tracks for rhythm. As the Classic 30 is an open-back amp, mic it front and back(just mute the back mic while you record). After you track it, stick a plugin on the rear track and polarity reverse it. Now mix the two tracks (front mic and rear mic) and see what you get with different balances of the two(zoom way in if you want to slip the rear mic track to line up perfectly with the front mic). Don't forget that sometimes, LESS IS MORE. So don't feel compelled to add dozens of tracks unless it helps the song.
Old 02-26-2008, 02:50 AM
Stiff Stiff is offline
Wow... This is near impossible to answer without hearing what you got and what you're aiming for. Albee is right about doubling, this is done with many instruments, not least guitars... But I think more importantly you should look at the overall arrangement.
What style of music are we talking about BTW?
Daily news & reviews
www.ProToolerBlog.com
Old 02-26-2008, 08:00 PM
I'll be recording church music like Chris Tomlin, or David Crowder. Very simple mix. Or more of a secular point of style, probably something like John mayer's room for squares.
Old 02-27-2008, 01:49 PM
shultzee13 shultzee13 is offline
Ace Frehley from Kiss actually had his guitar tracks stacked 24 times for "Detroit Rock City"
Pretty crazy uh? I actually stack everything when I record in Pro Tools. It makes everything sound so much fuller. Just duplicate the tracks after you record the takes you like. I think you'll be amazed at how much better it sounds. Pan one guitar track to the left, one to the right and then drive the 3rd one straight up center. It's very, very full sounding.
Pro Tools 11.3.1 & 10.3.8
Interface - Focusrite Clarett Pre2/Clarett Octopre
Computer - Mac Mini 2.5 GHz Intel Core i5, 16GB
OS - Yosemite
Monitors - Yamaha HS8
Old 02-27-2008, 03:23 PM
davegibbon davegibbon is offline
Behold the power of the "Pad". If you have Xpand!, try mucking around with some subtle pads. They don't have to be loud, just sit them back in the mix. If you find the right one, you can almost blend it so that it sounds like it's the tail of your guitar sound.
Dave
Old 03-01-2008, 06:40 AM
audiogeekzine audiogeekzine is offline
you must be joking.
Right?
I hope you're joking because I laughed at what you said.
Duplicating tracks is no substitute for double tracking.
What you've accomplished with the method you've described is made a mono sound louder. Its not stereo just because it comes out of two speakers! Its not fatter because it's louder!
@theaudiogeek
| www.EPICSounds.ca | www.AudioGeekZine.com | www.HomeRecordingShow.com |
Old 03-01-2008, 09:34 AM
yamlan yamlan is offline
Do you have drum loops and/or percussions playing with the live drum tracks. Programs like Stylus RMX have tons of filler loops to play under the live drums. This really adds flavor and depth to an arrangement.
Is the bass line dull? In other words, is the bass going 1-2-3-4 or 1-thicka-2-thicka-3-digada-4? You'd be surprised how much just changing the bass feel can fill up a particular arrangement. Same for the drums.
Adding subtle delays to arpeggios can help fill up the arrangement.
Record the guitar twice, straight the first time then vary the strumming on the same part the second time. Pan both parts left and right in the mix. Works sometimes.
You said you are producing music for your church. What is Christian music without lush string arrangements? Try playing 4ths and 5ths on top of the keyboard chords. Alternate between low and high notes.
I produce various styles of music. It happens all the time where an arrangement may seem empty until the vocals are recorded. Many times a song that I thought was empty ended up needing something taking out once the vocals chimed in. Once I get the core instruments laid down, I try to get the singer(s) to record a rough track. Then I finish the arrangement around the vocals - many times I find that it is already done once the vocals are recorded.
Old 03-04-2008, 06:51 PM
Eless Eless is offline
If you're trying to make it sound like Tomlin or Crowder... "simple" isn't what you're looking for. The "big-hitters" in praise and worship music are very big on drum loops, synth lines, arpeggiators, and other such "fillers." Specifically Crowder. In his band, the drummer is always doing very simple beats, and the drum machine really picks up the slack. With Tomlin, there is a lot of synth pads.
The other thing that both of these artists are huge on is COMPRESSION. HEAVY, HEAVY, HEAVY COMPRESSION!!! I know some guys on the board are probably going to be pretty upset about suggesting HUGE amounts of compression, but it's what gives them their sound. The lead vocal and the snare are the most obvious, but the acoustic guitar gets quite a bit as well. Listen to Crowder's "Illuminate" with a pair of headphones and listen to his vowels in the lead vocals and you'll hear what I'm talking about.
What kind of instrumentation do you have? I'm very into praise and worship music. I'm in a P&W band, and have recorded several projects for this type of music. If you'd like, I could listen to it and give some more specific pointers. Private message me if you want.
Cory
Old 03-05-2008, 08:53 AM
...his consonants... not his vowels. it was a long day yesterday... sometimes basic English skills escape me.
Cory
shortcut for selected tracks fill window mhmh Tips & Tricks 2 12-15-2011 06:25 AM
Fill gap shortcut Peter Groom Post - Surround - Video 1 02-13-2007 12:31 PM
my studios done, now i need to fill it up richsorr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-02-2004 08:10 AM
Studio is done, Help me fill it up! spicyitaliano General Discussion 13 04-27-2004 08:38 AM
Anyone using PT 6... fill us in Seller Pro Tools TDM Systems (Mac) 19 02-14-2003 10:24 AM
