New Computer, New Opening Error Message
Good morning, and Merry Christmas / Happy New Year to all... So I got a new Microsoft desktop, 32 gig ram. If I need to post a Sandra Report for this, I'll figure out how to do that.. So, after I've downloaded from my Avid account the PT 2018.4 and there was no problem with the download, i restarted the computer and I hit the button to open'er up... And surprise, I got this error message..
Could not complete your request because Assertion in "E:\Code\222370\ProTools\AAE\Source\AAX\CFicAAXWid get.cpp",line 822. This was the initial time I was trying to open up the program.. I appreciate anyone having thoughts as to what I need to do.. Thank you so much, Rich |
Re: New Computer, New Opening Error Message
When you get an assert Google the error message, especially file name. You will find past threads on DUC in this case. I’ll leave you to do that search for yourself.
And yes if you want help, provide the expected info. Windows version, esp. in this case… interface you are trying to use and driver version… and yes if you are running on Windows you should be able to produce a Sandra report without thinking about it. |
Good advice from Darryl. Taking it a bit further, since the message addresses drive E:, what is drive E:? How is it formatted? What happens if you disconnect that drive? Troubleshooting is not always obvious or easy for everyone, so my best advice is: break things down to the least number of things needed to give the most basic function and test that configuration. If it works as expected, then add back something that was removed and test again. Be methodical and take notes because that kind of information helps us help you
This ASSERT has a lot of past posts about it, and an Avid Knowledge Base article and typically is easy to resolve. It does not deserve yet another thread on DUC about this, unless all that existing easily found info is not solving this problem. |
I did check out the other posts and there's lots of talk about Asio4all.. I remember buying a one time incident code when I first got the laptop I've been using, and I remember the person installing the Asio4all drivers.. I'm gonna figure it out.. Albee, you made me wonder which drive the E drive is?? I have three External drives, one of which is the main drive I record too. Thank you everyone for directions to take.. I'm not on that rig at the moment, but I may just get a Sandra report put together and post it. Take care
That specific error is typically solved with info from this KB article. Please let us know if that doesn't help.
• linkedin •
Strange Error Message When Opening PT | Pete Morten | Pro Tools 2019 | 3 | 03-06-2020 03:59 AM |
Error Message when Opening AAF File | seanmascot | Pro Tools 12 | 2 | 06-02-2017 04:30 PM |
Error message upon opening PT [solved] | sb_stefan | Pro Tools 12 | 1 | 03-11-2017 01:04 PM |
Error Message When Opening Sessions | Gorbies | Pro Tools 11 | 1 | 04-23-2014 10:11 PM |
PT crashes, upon opening a session..no error message | jaguffain | Pro Tools TDM Systems (Mac) | 9 | 04-25-2010 09:48 PM |
