Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 01-07-2009, 02:32 PM
robby2161 robby2161 is offline
Default Pro Tools MP 8 with M-Audio Fast Track Ultra 8R?
Just wondering if the new Fast Track Ultra 8R is compatible and works with Pro Tools M-Powered 8. I'm currently running M-Powered 7.4 with a FireWire 410. Also, will this new setup work on a Macbook (2GHZ Core 2 Duo, 2 GB RAM) with Leopard 10.5.4?
Old 01-07-2009, 11:12 PM
LesPaul666 LesPaul666 is offline
Default Re: Pro Tools MP 8 with M-Audio Fast Track Ultra 8R?
It's certainly supported(PT M-Powered, 7.4 cs3 or higher as well as Pro Tools 8).
I found the following issues in the support section with the Fast Track Ultra series and Pro Tools:
Known Issue: Playback Stops With -6101 Error in Higher Sampling Rates With a Buffer Size of 128
Workaround:
  • Change buffer setting to 256 or higher.
Known issue: Audio Playback is Muted When a Click Track is Present With No Audio
Workaround:
  • Open the Fast Track Ultra control panel
  • Slightly turn up the monitor faders for an unused analog input pair on the associated monitor tab
This should release the "mute" bug and allow normal use of the Fast Track Ultra with Pro Tools M-Powered.
Multiple M-Audio Fast Track Ultra 8R in Pro Tools 10 miki725 macOS 1 11-21-2013 10:00 PM
Pro Tools 10 Audio Interface Setup- Fast Track Ultra kwj3532 Pro Tools 10 5 02-21-2013 12:55 PM
Pro Tools SE Cant configure 8 separate tracks with M-Audio Fast track Ultra 8R harleycummins Pro Tools M-Powered (Win) 2 02-21-2012 11:41 AM
Pro Tools LE and M-audio Fast track Ultra howbotnik 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-16-2011 03:56 PM
Pro Tools M powered freezes repeatedly with M audio fast track Ultra sagarsarkar Pro Tools M-Powered (Win) 0 01-03-2011 02:34 PM
