still have -9094 errors
I have some -9094 errors. I want to know if its possible to have less sensible, and stable LE system? I have only 20% of cpu usage where is the issue?
I use : 002R Bla mod HD, Mbox2Mini Sony Vaio VGN-FE31H WD 320 GB 7200rpm firewire drive for audio PTLE 8.0 cs3 SiSoftware Sandra Processor Model : Intel(R) Core(TM)2 CPU T5500 @ 1.66GHz Speed : 1.66GHz Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Mobile, Dual-Core Internal Data Cache : 2x 32kB Synchronous, Write-Thru, 8-way set, 64 byte line size L2 On-board Cache : 1x 2MB ECC Synchronous, ATC, 8-way set, 64 byte line size, 2 threads sharing Mainboard Platform Compliance : Intel Centrino Mobile Technology Bus(es) : PCI PCIe PCMCIA CardBus USB FireWire/1394 i2c/SMBus MP Support : 1 Processor(s) MP APIC : No System BIOS : Phoenix Technologies LTD 17.00 System : Sony Corporation VGN-FE31H Mainboard : Sony Corporation VAIO Total Memory : 2GB DDR2-SDRAM Chipset 1 Model : Sony Corp 955XM/945GM/PM/GMS/940GML Express Processor to DRAM Controller Front Side Bus Speed : 4x 166MHz (664MHz data rate) Total Memory : 2GB DDR2-SDRAM Memory Bus Speed : 4x 132MHz (528MHz data rate) Video System Monitor/Panel : Default Monitor Monitor/Panel : Default Monitor Monitor/Panel : Default Monitor Monitor/Panel : Plug and Play Monitor Adapter : NVIDIA GeForce Go 7400 Imaging Device : Sony Visual Communication Camera VGP-VCC1 Physical Storage Devices Hard Disk : MemoryStick0 Device Hard Disk : SD1 Device Hard Disk : TOSHIBA MK1234GSX (112GB) Hard Disk : WD External HDD Device IEEE 1394 SBP2 Device Hard Disk : Generic USB Flash Disk USB Device CD-ROM/DVD : MAT[bleep][bleep][bleep][bleep]A DVD-RAM UJ-850S (CD 47X Rd, 63X Wr) (DVD 6X Rd, 8X Wr) CD-ROM/DVD : NERO IMAGEDRIVE2 SCSI CdRom Device Logical Storage Devices My Book (F:) : 298GB (1GB, 0% Free Space) (NTFS) Hard Disk (C:) : 56GB (24GB, 43% Free Space) (NTFS) VAIO (E:) : 56GB (7GB, 12% Free Space) (NTFS) Pro Tools LE (L:) : 7.9GB (CDFS) Removable Drive (I:) : N/A Removable Drive (J:) : N/A Peripherals Serial/Parallel Port(s) : 1 COM / 0 LPT USB Controller/Hub : Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C8 USB Controller/Hub : Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C9 USB Controller/Hub : Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27CA USB Controller/Hub : Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27CB USB Controller/Hub : Intel(R) 82801G (ICH7 Family) USB2 Enhanced Host Controller - 27CC USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Composite Device USB Controller/Hub : USB Mass Storage Device FireWire/1394 Controller/Hub : Texas Instruments OHCI Compliant IEEE 1394 Host Controller FireWire/1394 Controller/Hub : Texas Instruments OHCI Compliant IEEE 1394 Host Controller PCMCIA/CardBus Controller : Generic CardBus Controller Keyboard : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard Mouse : PS/2 Compatible Mouse Mouse : HID-compliant mouse Human Interface : Sony Notebook Control Device Human Interface : HID-compliant consumer control device Human Interface : HID-compliant device Human Interface : HID-compliant device Human Interface : USB Human Interface Device Human Interface : USB Human Interface Device Communication Device(s) Device : HDAUDIO SoftV92 Data Fax Modem with SmartCP Printers and Faxes Model : Send To OneNote 2007 Model : Microsoft XPS Document Writer Power Management Mains (AC) Line Status : On-Line Operating System(s) Windows System : Microsoft Windows XP/2002 Professional 5.01.2600 (Service Pack 3) Platform Compliance : Win32 x86 Network Services Network Drivers Enabled : No Performance Tips Notice 5901 : CD 1x= 150kB/s; Exercise caution when comparing measured versus published ratings. Notice 5902 : DVD 1x= 11.08Mbps Exercise caution when comparing measured versus published ratings. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. Scubadrum |
Re: still have -9094 errors
honestly? who knows. i have a fully qualified pc and i still get errors.
one thing i did and it seems to have given me less errors is to change my nvidia geforce 7200 256mb for an ATI radeon 128mb. im still getting errors but not as many as before. |
There are a few things that I can see that could cause problems on your system, but there is one that stands out like a sore thumb:
That pretty much says it right there. Some other issues: This little sony is not something I would expect impressive results from Pro Tools on. I'm just sayin'... Pro Tools usually does not like Virtual drives. Disable Image Drive before using Pro Tools. Quote:
Is the fax/modem really necessary? If so, you should try to disable it while using Pro Tools. If not, disable it always.
-9094 errors in PT 10 | LukeHoward | Virtual Instruments | 5 | 12-15-2012 05:46 PM |
Help w/(9129),(9094) errors | joewilly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-07-2006 08:53 PM |
Cured my -9094 buffer errors! | stevegrisham | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-15-2004 08:16 PM |
9094 errors.. Please Help. Thanks in advance. | Smelt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 27 | 08-11-2003 12:57 AM |
9129 and 9094 errors | KdC | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-30-2000 10:34 AM |
