Application Launch Failure - shared library error
I am getting the following error when trying to launch PT 6.9.2 LE:
"Application Launch Failure - The application 'Pro Tools LE 6.9.2' could not be launched because of a shared library error: '4<Pro Tools PPC dbg> <Pro Tools PPC dbg> <DAE> <FreeFic>" I think the problem might have something to do with changing versions of ProTools. I had an HD1 system on this computer, running PT 7.2 HD. However, I had to swap out the card with a co-worker, and take his Digi 002. So i installed PT 6.7 (which came with the 002) and then updated to 6.9.2. Now I am getting this error. I am on a Dual 2.3 GHz PowerPC G5, 2.5 GB DDR2 SDRAM, running OS X version 10.4.8 I have already tried all of the normal courses of action recommended in the "help us help you" thread - trashing prefs, verifying/repairing permissions, etc. Any help would be greatly appreciated... I have some projects that I need to get crackin on! Thanks, Dan |
Re: Application Launch Failure - shared library error
This is caused by having mixed or missing components. I don't suppose you did a 'clean' uninstall of 7.2 before installing 6.x on here, did you? I'm assuming not.
What you should do: 1. Clean uninstall 7.2 HD 2. Clean uninstall 6.9.2 3. Restart and reinstall 6.9.2 |
Application launch Failure -- shared library error | digimutt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-25-2007 10:20 PM |
PT Launch Failure; "Shared library error?" | rickymix | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 01-04-2007 06:31 PM |
Launch Failure "Shared Library Error" - help? | rabbitears | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 04-09-2005 07:02 PM |
6.7 won't launch shared library error | nukepicnic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 11-23-2004 02:16 PM |
shared library error on launch | jg1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-10-2004 08:28 AM |
