  #41
Old 10-18-2021, 02:14 PM
EGS's Avatar
EGS EGS is offline
Default Re: Windows 11 comes out Oct 5th
Originally Posted by Benoni View Post
Yeah, its usually scaling that causes the issue, not necessarily the resolution.
So text cutoff is not a Win 11 issue, correct?
Click for audio/video demo
Click for resume
  #42
Old 10-18-2021, 03:21 PM
Benoni's Avatar
Benoni Benoni is offline
I don't have it on my main system which is 1920x1080 no scaling.
I will have it on a Surface Book which is 3000x2000 if I have scaling 200% ON (which is recommended)
If I turn off scaling there is no problem.
The same thing has happened since Windows 7 though, so it's not a Windows 11 thing per se.
Avid has known about this for awhile
https://avid.secure.force.com/pkb/ar...ors-on-Windows
If you turn scaling off BEFORE you launch Pro Tools, you can turn it back on AFTER Pro Tools launches and everything looks correct.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
  #43
Old 10-21-2021, 01:23 PM
Skwaidu Skwaidu is offline
Has anyone tried HDX with Win 11?
Windows 11 23H2, Intel i9-14900KS, MSI PRO Z690-A D4, 64 GB DDR4 4000MHz/CL18, Corsair HX1000, 1TB M.2 PCIe 4.0, 5TB M.2 PCIe 3.0, 2TB QVO, 2x6TB WD Black, Noctua NH-D15, Fractal Design Define R6 + RTX4070 - PT Ultimate 2024.3
Used to be/ Spare/ DAPS: Mac Pro 4,1 upgraded to 5,1 3,46Ghz 12 Core, 96GB RAM, OS SSD and Sata3 Audio SSD, macOS Mojave, PT Ultimate 2021.10, DAPS 3.7.1
HDX2, MTRX Studio & DAD MOM, HD I/O 16x16, Apogee AD/DA 16X/X-HD and ICON D-Command ES.
  #44
Old 10-21-2021, 02:56 PM
BobbyDazzler's Avatar
BobbyDazzler BobbyDazzler is offline
I was running scaling, so I'll give it a go without.
HP Z2 Xeon 6 Core, Blackmagic Decklink HD Extreme 3D Win10, PT ver.. Latest
  #45
Old 10-22-2021, 08:49 AM
jonwb jonwb is offline
I'm running Pro Tools 12.4 in Windows 10. This morning Microsoft informed me that my system can run Windows 11. I assume they'll be updating me at some point.
Is anyone running Pro Tools 12 with Win 11?
  #46
Old 11-21-2021, 06:45 PM
nsureit nsureit is offline
I’ve been using WIN11 with PT HD Ultimate+HDX for about a month now: MTRX Studio and a bunch of outboard preamps and processors (some on Dante), Dell XPS 15. No issues whatsoever. In fact, I’m no longer getting any PT errors when booting up Pro Tools.
  #47
Old 11-22-2021, 02:34 AM
Yes, my system is starting to be up as well, and HDX2 seems to work without issues. (i9-12900K, MSI PRO Z690-A DDDR4)
  #48
Old 11-22-2021, 04:16 AM
EGS's Avatar
EGS EGS is offline
Great! More working Windows 11 laptop & desktop rigs. It seems the W11 upgrade is not causing any problems!
Click for resume
  #49
Old 11-28-2021, 04:33 PM
I did notice a few minor graphical glitches on W11 so far - the Edit Window Comments field is not showing text when entering, but shows entered text (and you can type in Track Rename instead)
Also, on Plugin type lists there seems to be some overflow problems if the first bracket goes taller than the screen (I have a bunch of 7.1.2 verbs showing all possible widths) - luckily I've used the search for plugins for a while already.
Today I had some issues where automation was not being written on my Icon D-Command, but changing through auto types in the Edit window (at least) fixed it - and I know it's on it's way out, some form of Eucon will be the next update...
  #50
Old 11-29-2021, 05:57 AM
EGS's Avatar
EGS EGS is offline
Are these minor bugs ONLY occurring in Win11? I'm trying to determine, specifically, if upgrading W10 to W11 creates any new issues for Pro Tools. Thanks!
Click for resume
Pro Tools tabbed windows in MacOs - Windows configuration not working hugocentrique macOS 3 11-06-2023 05:26 AM
Audio glitches with Fast Track Ultra on Windows 10 after updating Windows 10 GregS FireWire & USB Audio Interfaces (Win) 6 12-25-2015 03:40 PM
Windows Guide - Windows 7 Optimizations and Troubleshooting.[349411] cwsand 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 08-12-2010 01:46 PM
Is standalone Windows Audio Drivers v8.0.3 compatible with WINDOWS XP 64 ? VonHelvete 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 03-28-2010 10:01 AM
Windows server 2003+windows resource manager. odysseys 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-20-2003 10:02 AM
