Mixing converter brands
I am using Aurora 16 with my PTHD3 and my system has worked flawlessly for several months. I finally got extra digilink cables so this weekend I want to also hook up my Apogee 16ADX and Apogee 16DAX.
I am wondering if there are issues to b aware of. I am aware that I need to manually set the delay compensation for the Apogees. Any tricks or set up problems when trying to use both Aurora and Apogee? I also have a Big Ben laying around that I can use if it is helpful. |
Re: Mixing converter brands
Be aware that there are probably slightly different A/D convertor latency times between the two units. In practical use, that means you shouldn't record phase-related tracks partially on one unit and partially on the other. For instance, when recording a drum kit, don't run the toms through the Apogee and the overheads through the Aurora.
I would also recommend that you use the Big Ben. Using the Big Ben is a good idea any time you are sync'ing several digital convertors, especially the Non-Digidesign interfaces without Loop Sync in an HD rig. Use the setup recommendations on Apogee's web site as a guide for hookup.
www.clifnorrell.com |
Need gear advice bad? Pro Tools 10 & mixing brands of converters | Christian | Pro Tools HDX & HD Native Systems (Mac) | 1 | 03-21-2013 02:53 PM |
Need gear advice bad? Pro Tools 10 & mixing brands of converters | Christian | Pro Tools HDX & HD Native Systems (Mac) | 6 | 03-18-2013 09:56 PM |
Mixing RAM brands - same specs | SixChurchStreet | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-19-2007 08:48 AM |
CDR brands | proximityeffect | Pro Tools TDM Systems (Mac) | 6 | 02-23-2001 10:42 AM |
DDS 4 which brands | Kurtstudio | Pro Tools TDM Systems (Mac) | 0 | 04-27-2000 08:12 PM |
