Old 11-15-2004, 05:09 PM
Default Divide and Conquer - MachineControl Selection Bug
Problem: When using MachineControl, if transport=machine and you have machine follows edit insertion/scrub enabled and you cue your machine in reverse, you get a magical selection on the timeline!
Reproducible: Yes, 100%
Steps to reproduce:
1. Enable MachineControl
2. Set transport=machine
3. Enable machine follows edit insertion/scrub in Setups-->Preferences-->Machine Control
4. Cue your machine in reverse.
What should happen: Machine should cue in reverse, stop, and leave the timeline alone!
What does happen: Machine cues in reverse, and when stopped, creates a selection on the timeline from where the reverse command was issued to where the machine stopped!
One of our engineers ran into this bug today when he went to perform a layback and forgot to turn off machine follows edit insertion/scrub.
How many times must I complain about this before it is fixed?! It's already in the answerbase in three entries! Check out 27175 , 8110 , and 25329.
Please fix this! Anyone else running into this bug? Please pipe up if you are!
Thanks for reading.
HTML code is On
'Divide by zero' error after installing Pro Tools cs3 on Windows DigiTechSupt Technical Alerts 0 07-01-2009 10:18 AM
Structure? How to divide a sample(patch into multiplel parts gwiz31 Virtual Instruments 2 03-01-2008 04:56 PM
Divide and Conquer - Stop at Shuttle Speed Zero Chief Technician Post - Surround - Video 8 11-08-2004 06:20 PM
intger error(divide by zero) message noso 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-01-2004 02:55 PM
Can I divide 1 partition without ... east3rdst 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-21-2003 10:25 PM
