Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | Intro Discussion
Old 06-10-2022, 04:09 AM
amyhjm amyhjm is offline
Default Re: Pro Tools First Not Working with Focusrite Scarlett Solo 3
Hi, I hope you've already solved this problem but I'd like to share how I just solved it cuz this is the first webpage when I searched this problem lol
After setting up Focusrite USB ASIO as the playback engine, you should then setup the Output and Bus in the I/O.
Make sure the Output and Bus have the same name, and then tick the box of "Mapping to output" in Bus.
Highly recommend to watch this
https://www.youtube.com/watch?v=HLOEFhSDIGk&t=38s
Old 07-16-2022, 06:10 PM
djdubceast49 djdubceast49 is offline
If you can, change the sample rate to 44.1 unless the interface is default at 48. Pro tools first only works at 44.1 on my system, even when I switch, or did you allow the interface to be read by the computer? Did you get s pop up screen from the cpu for the interface?
PT 12.5 & Focusrite Scarlett Solo on Win 7 Kurout Third Party Interfaces 0 03-02-2018 04:13 AM
i/o setup with Focusrite Scarlett Solo Marvin Losch macOS 4 12-22-2017 05:07 AM
Newbie questions about audio interface (Focusrite Scarlett Solo) sb_stefan Third Party Interfaces 1 12-22-2015 06:18 AM
Focusrite Scarlett interface not working michaelray1284 Pro Tools | Intro Discussion 5 09-11-2015 04:42 PM
Pro Tools using Focusrite Scarlett 2i2-working!! baxteradio Pro Tools 12 1 09-08-2015 11:55 AM
