This just happened today. It seems to work fine with the smaller delay compensation or none but when i select the long delay compensation and hit ok. it closes my session and does not open it up again. when i go to open the session manual PT quits. After a restart i tried to put long dly comp back on again. the program responded the same way, closed the session and did not reopen it. so i attempted to open it manually and i got a Kernal panic. Anyone else having these types of problems? I mean this is happening on a New G5 dual 2 Ghz with 2.5 Gb RAM. the firmware is up to date and the this a fresh install of the program...any help is appreciated..thanks....
specs: G5 dual 2Ghz 2.5 GB RAM OS X.3.5 PT 6.4 HD3 (192's) |
Hello,
Have you tried the larest CS update for 6.4? If that fails try a fresh install of PT.. Use the install CD and select custom/uninstall then re-boot then re-install PT and then do the latest cs update for 6.4. Pro Tools TDM 6.4cs9 for HD Systems on Mac OS X under downloads/cs updates etc If all this fails!! then give a detailed list of everything!!? and DUC people will help i'm sure!! Regards Chris
You should also try the basic troubleshooting steps in the thread at the top of every forum.
Here's a direct link: Pro Tools Troubleshooting Let us know if you're still experiencing the problem after going through those steps. |
Help Selecting Laptop for PT9 (long) | maxspl | Pro Tools 9 | 1 | 11-25-2010 05:39 PM |
short vs long delay compensation sonic | koka | Pro Tools TDM Systems (Mac) | 3 | 05-08-2009 06:32 PM |
Parameters from "Long Delay" to "Long Delay II" | command_shift | Pro Tools TDM Systems (Mac) | 1 | 08-15-2005 04:57 AM |
Strange Behavior on Long Delay Compensation | rnt_u_listnng | Pro Tools TDM Systems (Mac) | 4 | 08-18-2004 08:41 PM |
selecting TDM plug-in quits PT | chieflh99 | Pro Tools TDM Systems (Mac) | 6 | 10-09-2003 10:51 PM |
