Old 05-01-2021, 01:30 PM
[email protected] sameer.kokkur@gmail.com is offline
Default Cant find Pro Tools after installing
Hi Folks,
I have a sort of a weird problem. I recently purchased the M-Audio (M-Track DUO). After going through few videos on installing pro tools I downloaded it.
Extracted the files and did the set up.
But weird enough, I didnt get the usual screens that pops up during installation. After everything was done, I tried to run the program. But guess what, the program is nowhere to be found on my system.
When I search for "pro tools" the computer just shows me the downloaded installation files folder.
No program or executable files found. Neither was the 'Avid' folder found in the programs folder under windows.
Can someone please help me. Am I doing something wrong.
Old 05-03-2021, 10:34 AM
junkgear's Avatar
junkgear junkgear is offline
Default Re: Cant find Pro Tools after installing
Hey Sameer,
It sounds like the installer failed, and very early in the process, which is why you have no Avid directory or any signs of Pro Tools. Why it failed is pretty hard to say since we know nothing about your system.
Make sure you are using the latest version of Pro Tools, which is 2021.3.
Make sure you have enough space on the drive you are installing it to, which should be your system drive (generally C:). Avid suggests 15GB of free space.
Check the Pro Tools System Requirements to make sure your system can run Pro Tools.
Lastly, you can check the Windows Event Viewer. Look in the Windows logs and check the Setup, System and Application sections for errors. It may be easier to run the installer again, then look in the Event Viewer as the errors will be at the top of the list.
Let us know what you find and we will try and get you going.
Will
System Details
Old 05-04-2021, 01:20 PM
Thanks for the reply.
I have a Dell XPS 13 system with core i9 8th Gen. 32 MB Ram 2TB SSD.
I am now trying to download the 2021.3 as you said.
I will try to install this and get back to you if any problems arise.
Thanks for the support.
Old 05-04-2021, 04:20 PM
Well, I downloaded and tried to install but no luck.
Below is the message that popped up 3 times
Windows ® Installer. V 5.0.19041.1
msiexec /Option <Required Parameter> [Optional Parameter]
Install Options
</package | /i> <Product.msi>
Installs or configures a product
/a <Product.msi>
Administrative install - Installs a product on the network
/j<u|m> <Product.msi> [/t <Transform List>] [/g <Language ID>]
Advertises a product - m to all users, u to current user
</uninstall | /x> <Product.msi | ProductCode>
Uninstalls the product
Display Options
/quiet
Quiet mode, no user interaction
/passive
Unattended mode - progress bar only
/q[n|b|r|f]
Sets user interface level
n - No UI
b - Basic UI
r - Reduced UI
f - Full UI (default)
/help
Help information
Restart Options
/norestart
Do not restart after the installation is complete
/promptrestart
Prompts the user for restart if necessary
/forcerestart
Always restart the computer after installation
Logging Options
/l[i|w|e|a|r|u|c|m|o|p|v|x|+|!|*] <LogFile>
i - Status messages
w - Nonfatal warnings
e - All error messages
a - Start up of actions
r - Action-specific records
u - User requests
c - Initial UI parameters
m - Out-of-memory or fatal exit information
o - Out-of-disk-space messages
p - Terminal properties
v - Verbose output
x - Extra debugging information
+ - Append to existing log file
! - Flush each line to the log
* - Log all information, except for v and x options
/log <LogFile>
Equivalent of /l* <LogFile>
Update Options
/update <Update1.msp>[;Update2.msp]
Applies update(s)
/uninstall <PatchCodeGuid>[;Update2.msp] /package <Product.msi | ProductCode>
Remove update(s) for a product
Repair Options
/f[p|e|c|m|s|o|d|a|u|v] <Product.msi | ProductCode>
Repairs a product
p - only if file is missing
o - if file is missing or an older version is installed (default)
e - if file is missing or an equal or older version is installed
d - if file is missing or a different version is installed
c - if file is missing or checksum does not match the calculated value
a - forces all files to be reinstalled
u - all required user-specific registry entries (default)
m - all required computer-specific registry entries (default)
s - all existing shortcuts (default)
v - runs from source and recaches local package
Setting Public Properties
[PROPERTY=PropertyValue]
Consult the Windows ® Installer SDK for additional documentation on the
command line syntax.
Copyright © Microsoft Corporation. All rights reserved.
Portions of this software are based in part on the work of the Independent JPEG Group.
Old 05-04-2021, 06:20 PM
junkgear's Avatar
The message you posted suggests that Windows is not working correctly on your system and is not allowing the Windows installer to do it’s job. I would start by troubleshooting Windows using the following clean boot procedure
Will
System Details
Old 05-05-2021, 04:11 PM
I performed the clean boot as advised.
When I ran the setup file below is the message I get.
Pending Pace License Support
Pending avid codecs
pending avid cloud client
pending avidlink
I dont know if this is normal!
Anyway I clicked ok and went ahead with the installation.
But now I am getting the same windows installer message that pops up around 3 times that I mentioned in the previous post.
I dont know what is wrong!
even after a clean boot the result is same!!
Old 05-10-2021, 02:09 PM
sw rec sw rec is offline
Do you have your i-lok account set up yet?
Sound desigers find inspiration in all sorts of places. Where do you find yours? Jiegel Post - Surround - Video 0 03-09-2017 09:05 AM
Help me find if my CPU is ok for Pro Tools ! TTSoundware Getting Started 1 09-02-2014 07:37 PM
Help me find if my CPU is ok for Pro Tools ! TTSoundware Getting Started 0 09-02-2014 02:11 PM
Pick up one of my guitar today to find it completely out of tune but what a find! Emcha_audio General Discussion 8 06-17-2014 04:46 PM
DIGI 002, Problem installing hardware driver "cannot find hardware" on install inevitable realisation 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 26 08-21-2003 02:03 AM
